A Thanksgiving Receipe!
Old Nov 20, 2001 | 11:51 PM
KED85's Avatar
Hi All and Happy Holidays.
Your receipe comes from the 1990 edition of the Chevy Raceshop Baretta that paced the Indy 500.
They had to modify a 1990 V-6 60* engine to up to 245 HP to lead the race & escape down pit row.
So their RPMS were WAY UP THERE.
Remember that detail.
An Aluminum 3.1 block, enlarged to 92mm bore & 84mm stroke (or 3.4!)
Used the aluminum SPLAYED VALVE (FWD ONLY VERSION!!!) heads ported & polished, fitted with CUSTOM MADE Falconer Rocker studs & Isky solid lifters, 110 lb springs, roller rockers by Crane.
Isky .562 lift cam 88* overlap camshaft.
10.5 to 1 compression CAST ALUMINUM pistons
Extra hard cast iron cross drilled crankshaft
Melling oil pump
Here's the best part for us, as we can duplicate this part.
A Modified production manifold was utilized with LARGER RUNNERS fitted for HIGH RPM POWER (one exits into the pits-before the green flag drops, at about 120 MPH or so) similar to that used on the Corvette L-98 & mates to a production Corvette L-98 throttle body with heating system removed (TB block off).
Fuel rails were made from Aeroquip fittings, while hi capiticy injectors (Buick turbo V-6 stock).
Exhaust is made from 1 5/8" diameter headers, 24" long, w/a 31" collector, exiting into a SINGLE 3" pipe out the drivers door.
Specs
HP 245 @ 6800RPM (can you say ZOOM!!)
Torque is 220 ft lbs 4500RPM
FWD axle ratio is 3:43
1/4 time is 13.8
0-60 MPH is 5.8
What is really said, ya can hot rod this V-6 60* powerplant.
BUT some of these tricks ONLY benfit ya where ya don't drive (when did you last shift at 6800 RPMS?).
Enjoy your holiday!
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
[This message has been edited by KED85 (edited November 21, 2001).]
Old Nov 20, 2001 | 11:57 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
you can still get the aluminum block, what's 3k+ between you and your dealership?
$150.00 2.8 Auto.
Blown Head Gasket.
turbo has arrived, but put on hold (4 now)
USAF-Giving the enemy the oppertunity to die for their country
Old Nov 21, 2001 | 03:03 PM
BitchinRS's Avatar
Sweet!!!
was that HP rating rear wheel or at the fly wheel?
Old Nov 21, 2001 | 04:31 PM
WaynesRS's Avatar
better add some cheese in there with that .Cus your ganna need the cheese to do that
Old Nov 21, 2001 | 09:47 PM
KED85's Avatar
The hp answer was not offered in the article.
I'd guesstimate, engine on dyno
Chat Soon,
KED85
Karl
Kj Rockz
Pacific Region
Nov 26, 2004 06:04 AM
Kj Rockz
Nov 25, 2004 09:05 PM
3.8TransAM
Nov 25, 2004 02:34 PM
twysted87
Mid-Atlantic Region
Nov 24, 2004 08:58 PM
9D1BURD
Dec 1, 2003 05:33 PM
