weird tranny noise
Old Nov 19, 2001 | 06:21 PM
88camaro's Avatar
weird tranny noise
all of the gears on m 2.8 are working fine except the Reverse one
what happens is, when i put it in reverse there is a metal grinding sound but eventually it enters, wats happening there
BTW its an 88 mpfi 2.8 W/t manual. trans.
thnx in advance
AK
Old Nov 19, 2001 | 06:24 PM
Paul_Hughes_87 T/A's Avatar
Car: Chrysler 300c
Engine: 5.7L Hemi
Transmission: 5spd auto
Axle/Gears: 2.89
normal mine does it to its the syncros just put the shifter in first , second then put it in reverse it works for me all the time
DO NOT RELEASE THE CLUTCH UNTIL YOU ARE IN REVERSE
Moderator of the Ontario board
1987 Trans AM
  • 305 LG4 5.0L
  • WS6
  • T5 (former 700R4)
  • 3.23 posi
  • 152,000km
  • Black on gold trim
  • t- tops
  • K&N
  • Flowmaster 80 series
  • Gutted Cat
  • P225 on the front P255 on the back
  • Sony X-plod deck
  • Kenwood 4 X 6s
  • Prestige 6 x 9s
  • 2 crunch 10" bandpass
  • Boss 500w X 2 amp
IN PROGRESS
t5 swap
status:
swap complete
MAIL ME
paulhughes@home.com
KILLS:
87 IROC-Z, 79 Corvette, 93 Honda civic si , 88 MUSTANG H.O, 98 Mustang , 99? Dodge Ram 2500, 95 Acura Integra, 00 Cavalier z24, many many ricers
Favorite losses
87 Grand National, 99 Viper Rt/10, 69 Firebird
my ride
Old Nov 20, 2001 | 04:43 PM
iroc420's Avatar
Yeah, Its normal mine does it to. What I do is put it into 5th than reverse while having the clutch engaged.
Old Nov 22, 2001 | 01:42 PM
88camaro's Avatar
thanks allot i will try that
amother question though, yeasterday when i was at a stop light and put it into first it started moving and then bang it jumped right out,
now im not sure if i put it in all the way (driving stick for only 2 month), or either my transmission is toast , it never popped out before.
if its a transmission problem, is it fixable?
thnx again
AK
Old Nov 22, 2001 | 06:59 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Yep that is pretty normal, just the syncromesh for reverse has worn out... nothing to worry about, its when you get grinding in the forward mothing you have to worry.
Dads old S-15 use to grind like crazy to get it in reverse, but if you just do what the other guys say, putin 1st then 2nd, then go to reverse it will still work fine. No worrys your tranny is still with you.
Old Nov 23, 2001 | 11:10 AM
KED85's Avatar
I started driving in 1972.
The car I learned to "Stick shift" drive was the 1966 I got from my Dad as my High School car.
(It only cost, in 1972 dollars, $1,750. Yes, that little. ALL CARS BCK THEN, DID COST VERY LITTLE!)
That M-20 4-speed tranny also grinded, going into reverse. ALL GM do this.
Way to do this trick is, push in clutch, pull shifter into second, up, then left to reverse. You will not grind gears, as you have spun synchros within the tranny, by doing that action.
If you "inch ahead" pushing in clutch and in first at a light, you are having some clutch problems.
Need to have clutch adjusted or checked out, as it may be worn down, in need of replacing the clutch.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Nov 23, 2001 | 11:41 AM
88camaro's Avatar
my cluch works fine, i've replaced everything there myself when i rebuilt my engine
the whole cluch asambly pressure plate, and had my flywheel grinded.
so the cluch is fine
im worrid how many miles do i have left before i have to replace the tranny
BTW thanks allot for the help the reverse thing works with shifting into 5th (1st ,2nd too far away)
thanks allot
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
bjpotter
Oct 4, 2015 07:48 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
