Code 32-EGR again
Old Nov 24, 2001 | 07:04 PM
dsaint1347's Avatar
Code 32-EGR again
I was just wondering if it's possible to completly take off the EGR valve and give it a good cleaning would it cure the problem of my car stalling when it's warm. The other day I was getting off the highway doing about 40mph on a turn when it suddenly died on me I almost went off the road luckily my emergency brakes work (almost pooed in my pants) It's also embarresing stalling in city traffic.
1990 Red rs camaro
Dynomax catback
K-N filter
[This message has been edited by dsaint1347 (edited November 24, 2001).]
Old Nov 25, 2001 | 06:16 PM
dsaint1347's Avatar
btt
Old Nov 26, 2001 | 02:06 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
If you have a 90-92 i took mne apart and cleand it just be careful of the gasket inside i nevercould find a new gasket oh and jus clean he pintales they will fall out so be careful. i also oild them so they moved better cuz they were all stuck in 1 position
Old Nov 26, 2001 | 07:35 PM
dsaint1347's Avatar
Thanks for your reply, by the way what kind of oil did you use and did it eliminate the 32 fail code
Old Nov 26, 2001 | 07:39 PM
FAST RS's Avatar
i cant remebr what its called its in a limegreen can its like WD-40. the reason i had the code 32 was becasue my connector was shot to hell check your out that might be the problem. just be careful of the gasket you cant find it anywere so if it gets messed up your a SOL
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
