BrianK and SAEspinz80 Read This
Old Nov 27, 2001 | 12:23 PM
427camaro's Avatar
Car: 05 Nissan Xterra
Engine: 4.0L DOHC
Transmission: 5 Speed Auto w/ OD
How does that 'cold air intake' work that yall set up? How is it different from the stock way, besides looks? Is the way it's mounted how the 'cold' air comes in?
I don't know if I asked these so that yall know what I'm asking, but try to answer please!
Reference:
2.8 Liter V6
No Current Mods
Third Generation Camaro Site
Old Nov 27, 2001 | 02:32 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Cool, that's a bitchin' compare between the two systems... you can see the lack of MAF sensor in the top photo, and it's appearance in BrianK's car...
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Nov 27, 2001 | 03:14 PM
SAEspinz80's Avatar
i can't see brianK's setup....wish i could. don't know why the picture didn't show up.
how does "mine" work. well basically you are 1) taking all the narrow kinks and bends out of the factury ducting. and 2) updgrading to a 3" wide tube so the air flows MUCH MUCH easier. it practically shoot right into the TB.
and 3) its stuck as close to the fender wall as possible to get farther away from the engine as to get the coolest air possible. my next step, which i got from KED85 and TomP is to enclose it on all sides except the bottom to block off even more engine heat that may be getting in there. overall its a huge increase over stock. you can hear the air being sucked in at idle, and gulped when you hit the trottle. so basically i am getting the coolest air possible near the coolant resivoir, which is most likely coming from the fender area.
i don't know too much about maf's so i wish i could see briank's pics....but hope that helps
[This message has been edited by SAEspinz80 (edited November 27, 2001).]
Old Nov 27, 2001 | 06:25 PM
Brian K's Avatar
I had drop in K&N's they are great.. I was looking for something better and different that would flow the most. This setup does.
or
http://www.geocities.com/overlift/Dcp02084.jpg
Old Nov 27, 2001 | 07:19 PM
stuart69427's Avatar
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
hey Brian K,
You mentioned in a post about a year ago for someone to do a RAM Cold Air. Could this be done and how would you do it?
'88 2.8 V6 Sport Coupe
Navy Blue w/ light Grey GFX
'shorty' Rear Wing
cybergarage.cjb.net
stuart69427@aol.com
Old Nov 28, 2001 | 11:13 AM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
I am still not seeing he picture so I thought I would try to post it for others to see, Brian and Spinz nice setups, I love them both.
okay no such luck, well what I did was copy the target URL, and paste it in the browser and it worked for me good luck guys.
[This message has been edited by Joe_L (edited November 28, 2001).]
Bubbajones_ya
Jul 6, 2024 08:32 PM
sahlomonic
Sep 20, 2015 07:15 PM
eustodp
Sep 20, 2015 05:09 PM
Rally Smith
Sep 14, 2015 06:59 PM
sandman92084
Sep 12, 2015 10:27 PM
