ignition coil connector wires, someone check color please
Old Oct 16, 2011 | 02:05 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
I need to know the position and color of the wires on the grey ignition coil 2 pin connector, so as to know which lead goes to which wire on the harness.
Old Oct 16, 2011 | 02:07 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: ignition coil connector wires, someone check color please
Pink goes to positive and white goes to negative.
Old Oct 16, 2011 | 02:35 PM
Engine: 3.8, 3.4
I need to know which wire on the connector is positive and which is negative, either by pin letter or physical location on the ignition coil terminal because I do not have the original connector so my wire colors are different.
Old Oct 16, 2011 | 02:48 PM
Nysm1's Avatar
Car: 1988 Firebird
Engine: 2.8L V6 MPFI
Transmission: 4 Speed Auto
I believe its the one on the top when u connect it... Don't quote me but that's how it is on the 88 Firebird
Old Oct 16, 2011 | 03:05 PM
http://www.google.ca/search?tbm=isch...w=1304&bih=683
Old Oct 16, 2011 | 07:26 PM
project89's Avatar
here u go , btw the white wire on the power lead does not goto ground, it goes to the white tach wire
Attached Thumbnails ignition coil connector wires, someone check color please-images.jpg   ignition coil connector wires, someone check color please-ew8hei.gif
Old Oct 16, 2011 | 09:57 PM
Engine: 3.8, 3.4
Yeah, I was actually able to figure it out on my own, dug up a complete wiring schematic from an old thread of mine, plus I got the other 4 wires for ignition wired up and only 2 were left and one was tach, and the other power, as for the location I googled that. Good news is I was able to check my repin of my ECU harness back to stock, every single wire is exactly where it should be, so in theory I won't have any drama when I try to fire it up tomorrow. (was forced to abandon my DIS swap attempt, due to the untimely demise of my DD, courtesy of lack of maintenance by the PO.
So basically I need my camaro yesterday, atm I am still in school (5 days a week), AND I just started working(3 days a week), car died literally the day before my first day of work. Hopefully all goes smooth tomorrow and she fires right up and I find the parts I need to finish making it road ready.
Thanks all for the replies though, time was crucial, was supposed to fire it today, but I need 3 new ECU harness pins, and there is absolutely nowhere to get something like that on a sunday, I am not even sure I know of a place that would carry them, fortunately my school has a **** ton of them around.
BRoss99
Aug 10, 2025 05:08 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
92projectcamaro
Aug 6, 2015 01:20 PM
