Will 95 3.5 camaro 8mm taylor plugwires work on my 88 2.8 ?
Old Nov 25, 2001 | 08:40 PM
WaynesRS's Avatar
I'll have to order the cranefire wires I know it .Don't have time to make this accel wires and dont know if i like me .But found some 8mm taylor wires at thunderracing about 20 min from my house .
Wayne
Old Nov 25, 2001 | 08:49 PM
Ovrclck350's Avatar
LOL, I wanna know if 98 wires will work on a 95 if anyone knows.....
BTW Wayne, I DO know the 98's won't work on a 92/88...the boots are different.
Old Nov 25, 2001 | 08:53 PM
WaynesRS's Avatar
thanx bro
typo ...3.5 camaro ...no ..3.4 camaro
Billy, I just knew you were someone saying " uh you mean a 3.4 , they did not make 3.5 camaros " ..heh
Old Nov 25, 2001 | 10:52 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
I dunno dude. The 3.4 used DIS which is mounted on the driver side of the engine. Because of this, it meant that there were 3 LONG wires and 3 SHORT wires.
With our motors, it's really hard to say wheather or not those 3 SHORT wires would be long enough.....shrug
-Dan
-1990 3.1L RS
-Mods? no
-Slow? yes
-*Slowly* collecting parts for T5 swap
Old Nov 25, 2001 | 11:10 PM
WaynesRS's Avatar
Thanx anyway dood . I found some 3.1 wires 8mm for 92 camaro , dont remember what brand .but would those work ?
Old Nov 26, 2001 | 12:16 AM
Engine: LH0 3.1L
Yeah, those'll work. No difference between 2.8/3.1.
Old Nov 26, 2001 | 02:00 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
The 4th gen camaros use a electronic DIST at least from the ones i see and its mounted up front of the engineif i remeber right soo im pretty sure they wont fit
Old Nov 26, 2001 | 11:03 AM
KED85's Avatar
Wayne, by opeing the box you obtain from the vendor, you should know immediatly, if the plug wires will work.
BUT Wayne, IF YOUR RIDE IS UNDER WARRANTY, why are you doing this?
GO BACK TO THEM AND SEEK CUSTOMER SATISFACTION!!
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Nov 26, 2001 | 03:15 PM
WaynesRS's Avatar
Ok , I just got back from the shop .There is no detonation . well they didnt hear any noise .The cracked plug is just commen the mechanic said " we see those on bosh and delcos, its commen . So Im not worried about that . My wires look rather ghetofied right now , but hey it works ! I have one grey 8mm wire hooked up on one side with wire connectors keeping it away from the heat .The reason I did not take it to the shop at first is b/c I was scard it was going to be something not under warranty WHICH IT WAS .My fuel injectors need to be cleaned .They had to put my car on the computer though and they not only found that they found the idle needed adjusting and something to do with the TBS cable . All this total well be $275 , BUT im just thinking hey , just go back wed and pay the $60 computer test charge and slap some 17 pd inejectors in that puppy on my Chirstmas break .Is it hard to install injectors guys ? I mean if its cheaper I might as well just put some new ones in myself , if i can do it . So even though that sparkplug was cracked and a wired craked that was not causing it to miss slightly , it was the idle and tbs ...The other noise that might still be detonation , IM NOT worried about cus I know the owner real well and Im sure even if the car is 1000 miles out of warranty he would have it fixed ....Wayne .
Old Nov 26, 2001 | 06:53 PM
WaynesRS's Avatar
<font face="Verdana, Arial" size="2">Originally posted by KED85:
</font>
I have a $30 set of accel 8mm wires that wont work .They wont fit on the distributor .The guy at the parts (the manager ) told me they would work when I got them . Now the anushole won't take them back cus he said they have been on the car , I said yeah but the car was not running .I could have shoved em up his a$$ , I was so mad ! ...I found some Crane firewired 8.5 mm that Im going to get .for $30
Old Nov 26, 2001 | 06:57 PM
WaynesRS's Avatar
It's plugwires galore in my utility room heh .The other set of accel wires I have that you have to make , i screwed em up .O-well ya learn ...I think I can fix them , but have not had the patients .Then I have 7mms that I took off from chaning them when I thougth all wires were bad , then i have some 8mm cheap wires that seem good that someone sold me by mistake ..I have more wires than the parts store
Old Nov 26, 2001 | 08:42 PM
WaynesRS's Avatar
<font face="Verdana, Arial" size="2">Originally posted by WaynesRS:
Ok , I just got back from the shop .There is no detonation . well they didnt hear any noise .The cracked plug is just commen the mechanic said " we see those on bosh and delcos, its commen . So Im not worried about that . My wires look rather ghetofied right now , but hey it works ! I have one grey 8mm wire hooked up on one side with wire connectors keeping it away from the heat .The reason I did not take it to the shop at first is b/c I was scard it was going to be something not under warranty WHICH IT WAS .My fuel injectors need to be cleaned .They had to put my car on the computer though and they not only found that they found the idle needed adjusting and something to do with the TBS cable . All this total well be $275 , BUT im just thinking hey , just go back wed and pay the $60 computer test charge and slap some 17 pd inejectors in that puppy on my Chirstmas break .Is it hard to install injectors guys ? I mean if its cheaper I might as well just put some new ones in myself , if i can do it . So even though that sparkplug was cracked and a wired craked that was not causing it to miss slightly , it was the idle and tbs ...The other noise that might still be detonation , IM NOT worried about cus I know the owner real well and Im sure even if the car is 1000 miles out of warranty he would have it fixed ....Wayne .</font>
I think Im just ganna keep the injectors I have and get them cleaned . I did some research and I will see a nice gain in power from this . I mean i have to cus they have 180k miles on them and have never been cleaned . I learned that the 17 pound ones may not run with the computer unless i get a chip burned which i dont want to do and really wont be necessary unless i have my heads and intake ported and polished .
Wayne ....well have to tell you how it comes out after i get em cleaned wed
Old Nov 26, 2001 | 10:33 PM
KED85's Avatar
Hey Buddy,
Keep us posted.
Cleaning injectors, is easy, if left on the car.
I would suggest you speak to the manager of the store or even his supervisor!
That's such BS the won't take them back. Tell them you were told by their employees those plug wires would fit!
Chat Soon,
KED85
Karl
Old Nov 26, 2001 | 11:11 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
Wayne,
Whats the labeling on the package? I can tell you if they work for your application.
1972 Chevy Chevelle "Malibu"
Hooker Headers, Flowmaster 40 series mufflers, accel 8.8 wires,Edelbrock performer intake Edelbrock Carb, Msd Blaster 2 Coil, Torque Thrust "D" wheels
Click here for my Malibu information
In Memory of #3 Dale Earnhardt
Old Nov 27, 2001 | 07:34 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
tke the wires back to the store you got them from, ask to talk to the manager, if no joy, ask for region phone number. If they value you as a customer, they should be concerned about customer satisfaction.
As far as the insulator being cracked a "common happening", that shop is d*cking you around. especially all the crap you've been through recently.
Old Nov 27, 2001 | 04:10 PM
WaynesRS's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Graeme'sFirebird:
Wayne,
</font>
Accel 50404 there yellow with red boots .
Thanx Graeme ...I dunno maybe they will work with another dis cap though they wont snap on the dis ..Thanx again bud
Old Nov 27, 2001 | 04:17 PM
WaynesRS's Avatar
Hey Buddy,
Keep us posted.
</font>
Karl I have not told the rest , ya'll are not ganna belive this .I asked the manager in the store if they were the right ones ? he said "yeah , i think they are " Then I said , well do you know for sure "no let me check " He checked on the computer , I saw the anushole "yeah thats them" .So I went home tried to put them on , they did not work .I did not have time to mess with the car anymore that day , so I just put my old wires back on that .So a few days later I walk in .The same damn guy , THE MANAGER , that told me they were right and sold them to me would not take them back . I said , "well ya'l told me they fit , " he said well they were on the car .I didn't get ugly , I didn't get mad .Maybe I should have but I just walked out of there mad as hell ! This was a few months ago , so its prabably too late to do anything . I just don't go back to that store .I'll never step foot in their again ! Wayne
Old Nov 27, 2001 | 04:24 PM
WaynesRS's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Project: 85 2.8 bird:
</font>
That does not seem common to me either man , and I asked him twice .I think I should prabably go with colder plugs huh ?
Old Nov 27, 2001 | 04:29 PM
WaynesRS's Avatar
i think he was d*cking me around to !
Old Nov 27, 2001 | 05:26 PM
They wont SNAP on the distributor? They shouldnt snap, just push them in and thats it... you shouldnt hear any noises. Those ARE the correct wires, so...?
-Graeme
Old Nov 27, 2001 | 05:44 PM
WaynesRS's Avatar
-Graeme
</font>
I looked on the wrong box .Those will work , but thats the set I have to make ...The set I dont have to make (that wont work ) well i think wont work are ...well the number is 4047 these are pre-made ...Sorry I gave ya the wrong number man ...Wayne
Old Nov 27, 2001 | 05:53 PM
WaynesRS's Avatar
Graeme , I just tried putting it on again , the crimp is to small to go on the distributor . I have an old distributor cap that my grandpa had .It's one of those where you stick the crimp Inside the slot and it fit like a glove in there . wierd
Old Nov 27, 2001 | 06:05 PM
WaynesRS's Avatar
it seems like its prabably just made for that kind of distributor ,(whatever kind that is ) and not made for the kind I have .
Wayne
Old Nov 27, 2001 | 08:16 PM
Belker's Avatar
Accel 8.8mm Spiral Custom Fit #8879 is what I run on my '91
Old Nov 27, 2001 | 08:46 PM
WaynesRS's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Belker:
Accel 8.8mm Spiral Custom Fit #8879 is what I run on my '91</font>
dont know if this matters or not , but is it a firebird or camaro ? and how much were they ? thanx , Wayne
Old Nov 28, 2001 | 11:01 AM
KED85's Avatar
Wayne, call and ask for the regional store manager.
I think that jerk needs a few words from a superior!
And then, maybe you'll find a job there!!!
Call and ask for that name & number!
Chat Soon,
KED85
Karl
Old Nov 28, 2001 | 12:36 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah, they sold you the early socket-style type of wire... can you bring 'em back to another store? Spray some windex on a rag and clean off any major dirt...
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Nov 28, 2001 | 08:03 PM
WaynesRS's Avatar
Yeah , Im ganna bring them back to another store , where I know that manager and he's not a jerk .It will prabably be just an even swap for some crane firewires that fit exactly .He will have to order them for me .
Wayne ...Thanx guys for all help
Old Nov 28, 2001 | 08:05 PM
WaynesRS's Avatar
</font>
I think Id be a better manager than he is .Seems he does not know squat about cars Karl . .... ...He drives a honda accord staion wagon , YES , one of those rare station wagons and its ***** , he has it all riced out .
Wayne
Old Nov 30, 2001 | 10:10 PM
Belker's Avatar
The Accel 8.8 Custom Fit Performance Wire Set #8879 that I installed were on a '91 Camaro RS 3.1l. I bought them from http://www.summitracing.com for about $40 (Part#ACC-8879) and was happy with their service. I'm not sure they work any better than my old crappy ones because I also changed plugs, dist.cap, ign.coil at the same time. Overall I think they're really nice wires though, I admit, I don't have much experience to base this opion on.
Old Dec 1, 2001 | 02:59 AM
FAST RS's Avatar
Do what i have been forced into doing put the plugs back in the box make it look all nice and pretty... You still have the recipt right? Go to another store same store name you bought them at just one in a different location go in and say ya i bought theses a week or 2 ago how ever long ago it was and say i opend the box and went to put them on and they didnt fit you tried to put one on. They should return them say the boot for the dist isnt the right type and youwent out and bought a correct set allready and you wont be needing them. If they ask well why didn t you return them were you bought them say you were on your way home from work and there store is on your way home or make some excuse up. Should work ive done it before. Just make sure the manager does not work at the same store i ran into that problem so i went to the next store they had farther away and returned them.
If any thing i bet the manager jsut dosent want to admit he ****ed up.
Didnt realize 2 peoiple allready said take em back to another store oh well
[This message has been edited by FAST RS (edited December 01, 2001).]
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
86Base
Aug 8, 2015 01:34 PM
