2.8L idling probs..
Old Nov 28, 2001 | 05:31 PM
bored_blitzen's Avatar
2.8L idling probs..
hello. i have an '86 camaro with a 2.8L v-6. my idling went up because my o2 sensor went out. so i replace my o2 sensor and my idle is still above 10. i was wondering how to get it back to below 10. because it use to idle around 6-7.. thanks a lot..
Old Nov 28, 2001 | 06:25 PM
I Cant Drive 55's Avatar
Im not sure but you may have to reset the computer (ECM) by disconnecting your battery cable .
Also maybe a bad throttle position sensor.
Old Nov 29, 2001 | 09:15 AM
i know it's not the tps cause i have recently replaced that. and i have reset the computer but was wondering what to do to have the computer relearn the idle speed?
Old Nov 29, 2001 | 09:32 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
No kidding! I didn't think a bad oxy sensor would raise the car's idle. Er, wait.. did it? I mean, if the bad oxy sensor raised your idle, a good oxy sensor should've brought it back down...
What voltage did you adjust the TPS for at idle?
Other things- vacuum leaks, incorrect ignition timing, dirty throttle body, dirty IAC pintle & passageway...
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Dec 5, 2001 | 01:48 PM
jrand's Avatar
<font face="Verdana, Arial" size="2">Originally posted by bored_blitzen:
i know it's not the tps cause i have recently replaced that. and i have reset the computer but was wondering what to do to have the computer relearn the idle speed?</font>
i was having the same problem until i learned that for the computer to relearn idle speed you have to turn the ignition on for a few seconds, then off for 10, then back on. that was (and still is for some reason) the only way i can get my car to run actually.
Old Dec 7, 2001 | 07:47 PM
thanks a lot guys. i turned it on for 3 secs, then turned it off for 10 and it relearned the idle and is now idling where it should be.. i thank you again.
bored_blitzen
yellow '86 camaro w/ 2.8L multiport efi
no money so no mods (yet)
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
Chevy86 IROC-Z
Sep 7, 2015 01:13 AM
