Performance
Old Dec 1, 2011 | 12:27 AM
boostdprobe91's Avatar
Car: 88 camaro
Engine: 2.8l
Performance
Ok so I got my camaro running right now. Turns out it was just a bad spark plug wire. I changed all the plug wires, plugs, distrubtor cap and rotor, fuel filter and coil.
heres some pictures of my third gen!
I am wondering do headers help out in performance on the 2.8L engines and do the jet performance underdrive pulleys help?
Old Dec 1, 2011 | 01:02 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Performance
Yes. A little. But you may also get advice on more bang for the buck with a swap to bigger v6 or v8 for more power. All just time and money.
Old Dec 1, 2011 | 01:32 PM
Car: 88 camaro
Engine: 2.8l
Re: Performance
I don't really want to swap a bigger v6 into or a v8 because of fuel prices right now and the fact I have no place to do the swap. Anyways, my biggest plans for the car are to get the most horse power out of the 2.8 as possible. Like, I'm going to do headers, under drive pulleys, egr block off plate, a better exhaust system, ported intake and heads and some other stuff. Also I was wondering can the pontiac fiero gt cam be swapped into the 2.8l camaro? or is it the same one thats in the camaro?
Old Dec 1, 2011 | 01:35 PM
Car: 88 camaro
Engine: 2.8l
Re: Performance
Also I'm kinda curious about cold air intakes on these 2.8l's? Do they help? Make them run rich or lean? or what, like I know on civics they help out a lot but I've never had a camaro and im not sure if they would help on a camaro?
Old Dec 1, 2011 | 02:16 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Re: Performance
Search on the v6 forum. It's all there somewhere. Lots to read.
Old Dec 1, 2011 | 02:21 PM
Car: 88 camaro
Engine: 2.8l
Re: Performance
I thought this was the v6 forum...??? Can u send me the link to the v6 forum?
Old Dec 1, 2011 | 02:36 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Performance
There are stickys and they should be read.
They are at the top of the forum for a reason
https://www.thirdgen.org/forums/v6/5...w-intakes.html
https://www.thirdgen.org/forums/v6/5...ost-power.html
https://www.thirdgen.org/forums/v6/3...arts-60-a.html
And the most important sticky
https://www.thirdgen.org/forums/search.php
Old Dec 1, 2011 | 03:20 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Re: Performance
Not thinking. As Midias says the stickies are at the top. Read. Read. Read.
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
jrdturbo
Mar 31, 2016 02:58 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
