v6 3.1 engine bracket set up pics
Old Dec 10, 2011 | 06:21 PM
THEBEAST84's Avatar
Car: 84 z28 h.o./ 92 rs
Engine: 305 h/o /3.1 v6
Transmission: hybird turbo 350/t5 bog warner
Axle/Gears: non posi 3.73 / ls 3.42
I need a pics of a stock 1992 3.1 (rwd) (non factory ac) bracket set up. bc the shop that's putting my engine in my camaro is saying that my belt is too short ! ItS the same belt that came off my old 3.1 engine !!! I think they got somethings mixed up with the brackets !!! Thanks in advance !!!
Old Dec 10, 2011 | 06:27 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Re: v6 3.1 engine bracket set up pics
I'm pretty sure that ac was standard by then. Don't think there would have been a setup for a 3.1 without AC, but you might be able to find a setup for a 2.8 serpentine that didn't include it
Old Dec 10, 2011 | 06:34 PM
THEBEAST84's Avatar
Well whhen I bought the serptine belt a year and a half ago that what it was under I prolly should have said aftermarket ac my box and copresser looks nothing like gm produced in the 80 nor the 9o for that matter !!! Iive hit all the jy here in my town and I'm still looking !!! I have a post on here some where about my ac ill do more searching and see if I can dig up mor pics. Of my old 3.1 engine !!!
Old Dec 10, 2011 | 06:46 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Here are a few pics of mine. It is a 3.1L without A/c
Hope this helps
Attached Thumbnails v6 3.1 engine bracket set up pics-blackintake.jpg   v6 3.1 engine bracket set up pics-blackintake-1-.jpg
Old Dec 10, 2011 | 07:31 PM
THEBEAST84's Avatar
Thanks fast they helped a lot !!! The belt is not the issue but ill need the number to get a new bellt !!! The issuse now is the ac compressor brackets front and back ! I found some old pics of my first 3.1 my ac compressor was made zexel and the ac\ heater box waz made by wynns frosttemp !!! I remeber bc I posed here awhile back about finding info so I can get my ac \ heat back working !!!! Thanks in advance for any more help !!!
Old Dec 10, 2011 | 07:40 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Im lost are you trying to put the a/c back on the car?
Old Dec 10, 2011 | 07:48 PM
THEBEAST84's Avatar
The ac stuff is in the car !!! A shop is putting in a3.1 engine in my camaro I just wanna make sure they have the brackets right on the engine bc my belt is coming up too short !!!
I was explaining what kind of ac is in my car to the other guy that posted !!!
Old Dec 10, 2011 | 07:56 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Ahh i feel like an idiot. I know what your saying now.
Old Dec 10, 2011 | 08:12 PM
THEBEAST84's Avatar
Its ok my engine belt is serptine but ac runs off a seprate v belt set up. Not serptine like most v6s and v8 here on the board !!!
Anybody else on here with the wynns\frosttemp ac set up ?
Old Dec 11, 2011 | 08:54 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
No, it wasn't... I've seen a 91 without factory A/C... The A/C wiring was zip-tied to the rest of the harness, out of the way.
That A/C setup is aftermarket, and there is only one other guy on here who either has or used to have one similar, that was supposedly installed by Sears years ago. If you have a v-belt driving the compressor, then all of the old brackets and what not should be installed the same way as they came off of the old engine and the belt should work. I find it unlikely that the compressor would work on the factory brackets, and for that reason, the belt isn't going to work. You may need to have measurements taken to get a new belt if the compressor does fit the factory bracket, but then the belt probably isn't going to line up properly.
Old Dec 11, 2011 | 11:56 PM
THEBEAST84's Avatar
Well one of the issues are the water pump pulley I have the right one order from a guy off of this site the second one isi need to find the correct ac tensine pulley for the ac belt !!! as far as the brackets goes he has them correct I'm just waiting on the pulley to get here !!! That sucks about the aftermarket ac I found a place i
In jacksonville that got me connected to ac parts guy here in tallahassee
Thanks for all the help fellas
1992 Trans Am
May 10, 2023 07:19 PM
Fast355
Dec 2, 2016 06:33 PM
red90IROCls1
Aug 25, 2015 06:56 AM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
