2.8l wont start!!!!
Old Dec 30, 2011 | 08:54 PM
boostdprobe91's Avatar
Car: 88 camaro
Engine: 2.8l
2.8l wont start!!!!
Alright guys, here I am back again with another problem. I recently changed upper intake manifold gaskets on my car and I painted the upper intake manifold. Well ever since I changed the gaskets the car wont start at all. It will pop a couple times but nothing. I have everything hooked up right and dont beleive i damaged anything when doing the gasket swap. Can anyone tell me what might be wrong? I did unplug the throttle body sesnors and maf sesnor.
Old Dec 30, 2011 | 09:00 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Re: 2.8l wont start!!!!
yeah, sure sounds like something didn't get hooked up right. so many options, including a crack in a vacuum line, though I don't think that would prevent it from starting.
the good news is, I bet it's something simple. The bad news is, it's really hard to diagnose what's wrong over the internet. maybe take lots of pics from every angle?
Old Dec 30, 2011 | 09:02 PM
Car: 88 camaro
Engine: 2.8l
Yeah, I know its hard to fix a car over the internet. Im just no sure what to do i've went over everything. and cant figure it out!
Old Dec 30, 2011 | 09:06 PM
58mark's Avatar
I know man. if it ran for a second and shut off I would say double check the brake booster vacuum. If it just pops and never catches.... I just don't know.
Old Dec 30, 2011 | 09:23 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Im trying to think of all the things you would have to take off, throttle body, kick down cable..exc but could leave the cables on the TB and any senors(maters what you wanted to take off, IAC sensor clip, egr, 2 vaccum lines in back of the upper plentum(for a 2.8L)...well you could literly take it all back off and start over. Be thankful thats just a 30 minuet job to take apart and put back together.
When i know i have a problem and its usually a little problem, i take what i just assembled and take it back apart and look it over carfully as i put it back together again.
Old Jan 2, 2012 | 12:21 AM
Car: 88 camaro
Engine: 2.8l
I know I'm going to be hated on a lot for this but it actually turns out my spark plugs some how got fouled out and needed replaced. i checked everything finally I pulled out a plug and it was soaked in gas so I replaced all 6 plugs and it fired right up. Sounds like new now. Sorry for the dumb question.
Old Jan 2, 2012 | 12:29 AM
58mark's Avatar
All 6 of them went from being fine before you took off your intake to car wouldn't ever come close to starting afterwards?
Old Jan 6, 2012 | 09:31 PM
Car: 88 camaro
Engine: 2.8l
I believe, I forgot to plug in the mass air flow sensor and I believe thats what fouled them out! Now correct me if I'm wrong but wouldn't that do that.
Orr89RocZ
Apr 25, 2016 08:28 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
BurlyChev
Aug 16, 2015 09:08 PM
92camaroJoe
Aug 13, 2015 06:07 AM
gwade12
Aug 8, 2015 08:17 AM
