2.8 idle and hesitation
Old Feb 16, 2012 | 10:12 PM
thomaslog's Avatar
Car: 87 camaro rs
So i got this car around april of last year and it has been sitting in my backyard. Ive been repairing it little by little. I noticed when i turn it on it it idles at about 1500 to 2000 rpm and stays that high for about ten minutes, also when i hit the gas pedal it hesitates and takes a second to rev up. Any ideas of what could be my problem? Any help is appreciated.
Old Feb 24, 2012 | 10:45 AM
redneckcamaro's Avatar
Car: 1985 sport coupe
Engine: was 2.8 now 3.4
Transmission: 700r4 auto
Re: 2.8 idle and hesitation
check the timeing and IAC. the IAC have been known to be the answer in this problem. this also could be due to a vacume leak.
Old Feb 24, 2012 | 04:53 PM
19camaro83's Avatar
Car: 1983 camaro sport coupe
Engine: 2.8l v6 - stock motor
Transmission: NWC t-5
Axle/Gears: whatever came stock (?)
The hesitation sounds like a faulty accelerator pump to me.
Old Feb 26, 2012 | 02:35 AM
slowbot's Avatar
I would check the tps and the throttle position because mine would idle around 1450 when it was warm and i found out the screw that stops the throttle from bottoming out was screwed all the way out and reset it to a length that would keep a stable rpm with all my accessories running. If that checks out good check the vacuum lines.
Old Feb 26, 2012 | 08:11 AM
ex-x-fire's Avatar
Hey OP, alitlle info needed! Like year, we can only guess if its carbed or not.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Zane Story
Oct 8, 2015 12:40 PM
webeeZ28
Sep 14, 2015 12:00 PM
Ranbo108
Sep 9, 2015 12:20 PM
rjcme
Sep 5, 2015 01:23 PM
