Compression ratio
Old Mar 3, 2012 | 07:07 PM
ezrollin's Avatar
Compression ratio
I did a calculation on a dished piston with a 3.140 inch dia. / .270 inch deep dish and came up with 34 cc's.I also did one with a online calculator and came up with a different figure.Anyone want to give it a try ?
Old Mar 4, 2012 | 12:48 PM
ezrollin's Avatar
Re: Compression ratio
No math whiz here ?
Old Mar 4, 2012 | 08:45 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Well, it did come out as 33.974 cc's or something along those lines when I did it. But, the thing is, that dish is rather excessive for anything not actually using the top of the piston as the combustion chamber. Unless you're using a power adder from something like an Allison V-1710 turbocharged V12 (or was it supercharged? I forgot )...
Old Mar 4, 2012 | 09:14 PM
ezrollin's Avatar
That's what I got,just rounded it off. I'm building a turbo 3.4 / 3400 and wanted to calculate my compression ratio as accurately as possible.I found the 3400 heads listed with a 28.6 cc combustion chamber and the stock 3400 pistons with 28.6 cc dish,which I thought might be a misprint.My calculations with the after market 34 cc pistons give appox. 9:1 ratio depending on which head gasket and overbore,which is good for my purposes. Thanks.
InfernalVortex
Apr 20, 2021 11:31 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
