car wont start
Old Mar 25, 2012 | 05:14 PM
stud-foxxx's Avatar
car wont start
i am getting no spark at the plugs so i checked the coil and no spark there either. my question is what should i check before i buy a new one?
Old Mar 25, 2012 | 06:28 PM
project89's Avatar
Re: car wont start
make sure the coil is getting power with the key on
Old Mar 25, 2012 | 06:43 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: car wont start
check coil wire close for signs someone used a quick connect for a tach, they will cut the wires over time and kill power.
had only 3 strands left when I found mine to be the problem.
Old Mar 26, 2012 | 04:28 AM
stud-foxxx's Avatar
Re: car wont start
How would I check for power? I put a light tester on the thing that the plug wire goes onto that goes to the cap. Had no light and even tested the light afterwards incase I blew the light but it still worked
Old Apr 1, 2012 | 07:32 PM
stud-foxxx's Avatar
Re: car wont start
Just replaced the coil and still no spark. I got power going to the coil. Thinking next step is the module. Anyone else with ideas to check? Thank you. Need to get it running ASAP. When I tested for power I had power at one wire but not the other even tho its on the same connection. Is that correct or do I need power from both wires?
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
