Vacuum line to.... ?
Old Apr 7, 2012 | 06:29 AM
kpcrash's Avatar
Just started working on 3.1 - first time on this engine and despite everything I've read..... there is what appears to be a vacuum line connection on the back (dead center) of the intake plenum. I can't find it in Haynes/Chilton - just need to know where/if I should just close it off or where it should be connected. TIA
Old Apr 7, 2012 | 07:44 AM
ex-x-fire's Avatar
Re: Vacuum line to.... ?
Look at the vacuum diagram on the radiator support, you can also find them if you google it.
Old Apr 7, 2012 | 10:52 AM
kpcrash's Avatar
Thanks - had tried googling, no stickers under hood anymore. Found the loose hose when I took off the dizzy. +1 for finding hose, -10 for rusted out dizzy.
Old Apr 7, 2012 | 06:10 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Goes to the heater control head input, the cruise modulator by the washer tank, and the orb of power under the driver's side battery tray... IF it's off of the T in the back of the plenum that the brake booster SHOULD already be connected to. The one off to the left side of the engine (when looking at it from the pulley end) goes to the MAP sensor mounted to the cowl lip.
Old Apr 7, 2012 | 09:11 PM
92camarorv6's Avatar
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
whats the orb
Old Apr 7, 2012 | 09:16 PM
Engine: 2.7L V6
Axle/Gears: 4.41
The vac tank under the driver's side battery tray...
Old Apr 7, 2012 | 09:58 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Maverick we could sure use a good mechanic here in Az, be nice to have someone in the area that know there stuff!!! I always appreciate your good info
Old Apr 8, 2012 | 12:54 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Eh, if I was sure I could stand the heat, I'd probably end up working for my older sister out there either in or near Gold Canyon (I think that's at least where she was a couple years ago), if she still has her towing business. Which, the last I heard, she was thinking of getting out of after having 2 more kids...
gta892000
Aug 11, 2019 11:16 AM
camarohelp
Sep 12, 2015 05:45 PM
Doobie52
Sep 11, 2015 06:19 PM
IROCtometal
Sep 9, 2015 10:01 AM
snakeshooter
Sep 7, 2015 11:13 AM
