i think my alt died
Old Apr 15, 2012 | 03:50 PM
purple98haz28's Avatar
i think my alt died
ok my 85 2.8 camaro does a lot of sitting since we got a yukon to tote the kids. i went to drive it over a weekend and it started but when i put it in gear it died. went to restart and nothing so i checked battery voltage and only had like 6 volts.
jumped it off and checked charging system at battery and at back of alternator and its only chrging at 8.5volts up to 9 volts revved up. what gives it was working when i last drove it about a month ago.
i checked the belt and it is tight. i have never seen one charge at low voltage only all or none type of deal. does this sound like a bad alt or what else could i check? thanks brandon
Old Apr 15, 2012 | 03:59 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: i think my alt died
Well the best thing to do is take Alt. off and have it checked, then you would know for sure.
Old Apr 16, 2012 | 09:45 AM
Adrenaline1's Avatar
Car: 1982 Firebird
Engine: 2.8 N/A
Transmission: Manual 4 Speed
Or just replace it. Its a true PITA when you test it, it passes, and then your car dies in the middle of nowhere because you got a false reading from the test. Yes, it happens more than people realize. Something i didnt know until after it happend to me, go figure.
Old Apr 16, 2012 | 06:28 PM
Edwardgp's Avatar
Engine: 454-350
Old Apr 17, 2012 | 11:59 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
Sounds bad to me... Probably need a new battery too.
Old Apr 18, 2012 | 06:47 AM
Edwardgp's Avatar
Engine: 454-350
Don't forget to keep us posted on what you find out.
Old Apr 18, 2012 | 10:48 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
If the alternator isn't putting out ~14.6 volts its not actually charging the battery...so if you know you measured it right at only 8-9v its definitely bad. And if you have any doubt, jump it, and let it run and see if it dies or not.
Fanatic1074
Oct 3, 2022 05:57 AM
Gunner242
Dec 25, 2015 04:49 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Luigytico09
Oct 1, 2015 08:46 AM
