AC relay
Old Apr 18, 2012 | 11:46 PM
crazybird's Avatar
Car: 1987 firebird
AC relay
There are three relays on the fire wall driver side. Is one of them a AC relay?
I searched, but wasn't really clear.
crazybird's Avatar
Car: 1987 firebird
Re: AC relay
also where is the door lock relay? is it the same unit for the windows?
Old Apr 19, 2012 | 05:15 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: AC relay
The A/C relay is the one that has mostly green and blue wires...
There is no window relay. Except for the rear hatch release, which is under the pass side of the dash (if equipped).
Door lock relay is the metal box behind the driver's side kick panel...
Old Apr 19, 2012 | 06:26 PM
crazybird's Avatar
Car: 1987 firebird
Re: AC relay
ok cool found the lock relay and threw it out. the ac relay is one of the three on the firewall/drivers side correct? it has all green and blue wires to it? and those wires run under the engine to the passenger side correct? thanks bro!
Old Apr 19, 2012 | 06:29 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: AC relay
The A/C relay wires are MOSTLY blue and green... I think it's the only one of those 3 with a pink wire attached. There are no large wires as there are for the radiator fan and fuel pump relays.
Old Apr 19, 2012 | 06:52 PM
crazybird's Avatar
Car: 1987 firebird
Re: AC relay
ok i have 3 relays there. the only one that doesnt have a big wire going to it does not have a pink wire at all. but there is one with a pink wire but it has a large wire as well.
so is it true that the three relays are for the fan, the ac, and the fuel pump? i thought there was some maf relays there as well?
Old Apr 19, 2012 | 09:53 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: AC relay
Only MAF relay is right next to the MAF by the air can and charcoal can... There is no burnoff relay on the V6.
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
