intake question
Old Jun 18, 2012 | 10:32 PM
adamd4648's Avatar
Car: 1988 firebird
Engine: v6
Transmission: stock, auto
Axle/Gears: stock
intake question
there are a few people out there that say its no big deal to put your air filter directly on your throttle body.. but when you do that you pass up your MAF.. i custom made one so i kept my MAF is there any difference in power by just attaching your filter to your throttle body??
Old Jun 18, 2012 | 10:45 PM
project89's Avatar
Re: intake question
since u have a maf car u must keep the maf sensor hooked up.
most ppl who put the filter directly on the tb have a speed density ecm ( map sensor instead of a maf)
if u put utr filter directly on the throttlebody ur car will not run right
Old Jun 18, 2012 | 10:51 PM
adamd4648's Avatar
Car: 1988 firebird
Engine: v6
Axle/Gears: stock
Re: intake question
is there a way to convert it over to a MAP sensor??
Old Jun 18, 2012 | 11:41 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: intake question
Yes, change the ECM and some wiring.
Old Jun 19, 2012 | 08:17 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: intake question
Putting the air filter directly on the TB will also keep sucking in the heat from under the hood(little to no HP gain at all). The best way to add some HP is to route it so that you are sucking fresh air in from outside the engine bay. Cool air induction of somesort.
Can anyone confirm that a dual snorkle intake will not work on a firebird? Because I don't think it will(there is metal under where the intake would route the openings) If it does though, correct me and that is the best intake set up in my opinion to add a few extra HP and a little under the hood styling.
Old Jul 1, 2012 | 10:10 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: intake question
You don't need that, just use the setup from a '91-'92 GTA, it flows well enough for 240 HP, and no 3.1 is gonna make that.
Old Jul 1, 2012 | 11:13 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Re: intake question
I make more then 240Hp....
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
