Here we go ( Rod Bearing Replacement )
Old Jul 2, 2012 | 09:08 AM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Got a rod knock in the good ole V6. Going to see if some rod bearings with fix her up. Will be getting under the car today to get a look see, hoping to take the oil pan off and swap the bearings. Camaro beats the Mercedes's 8 MPG so I need to get it fixed. That and it brings me to tears to see it sit.
Old Jul 2, 2012 | 04:17 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
Re: Here we go ( Rod Bearing Replacement )
You'll probably need a crank and rod too.
Old Jul 2, 2012 | 10:52 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
1/1000 times you can just swap the bearing and be ok... the rest of the time it will spin again within a day or 2.
Old Jul 3, 2012 | 12:21 AM
project89's Avatar
take pictures if the crank journal and the rod so we can see how bad it is.
if and i mean if u are super lucky u can get a strip of emery cloth and poilish off the crank journal and slide a new bearing in place. and even after that it has to be babied big time or it will spin it again
Old Jul 3, 2012 | 12:20 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Since you're going to have to get a hoist and lift the engine up and off of the mounts anyways to get the oil pan out, you might as well do it right with a new rod (and crank kit if the journal is FUBARed). When the bearing spins out of the journal, the crank rides on the rod journal, widening it by grinding on it. Which means a new bearing isn't going to sit tight like it's supposed to and will spin again eventually.
Old Jul 5, 2012 | 07:15 AM
Car: 1989 Camaro RS
Engine: LH6
Will do.
If its bad enough, which it probably is, I've beat the **** out of this motor, I'll just buy another.
I haven't had the opportunity to get under the car, my Mercedes has been acting up.
Old Jul 5, 2012 | 07:17 PM
project89's Avatar
u dont need to lift the motor to remove the oil pan, u can rotate the crank in small steps to remove the pan
Old Jul 9, 2012 | 02:44 PM
Car: 1989 Camaro RS
Engine: LH6
I'm probably just going to buy a 3.4 and replace the motor. And swap in my cam, 1.6 RRs and valve springs.
Reborn756
Sep 4, 2015 03:42 AM
red90IROCls1
Aug 25, 2015 06:56 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
gwade12
Aug 8, 2015 08:17 AM
