2.8 to 2.8 swap questions
Car: 1986 firebird
Engine: 2.8l v6
Transmission: 5 speed
I bought an 86 firebird with a 2.8L v6 last week and got scamed because the engine didnt knock when i got it the next day is sounds has a deep hollow knock when it hits high revs. By chance i just happen to have bought this car because my 93 s10 that ran fine has a bad cluch and transmission but also has a 2.8L v6. seriously considering pulling the engine from the S10 and putting it in the firebird because i already own both. Thoughts and suggestions?
Car: 1986 firebird
Engine: 2.8l v6
Re: 2.8 to 2.8 swap questions
Never done this before and wasn't sure about mateing the s10 engine with the firebird cluch and trans
Transmission: 5-speed/T-5
That won't be an issue.
The only thing you will need to make sure of in that regard, is that there is a pilot bushing installed in the back of the crank to support the trans input shaft.
Car: 1986 firebird
Engine: 2.8l v6
Sorry im really quite new at this i have no idea what that means or what i would be looking for
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
If you don't know what a pilot bearing is, you should probably let someone else do the swap.
Car: 1986 firebird
Engine: 2.8l v6
Unfortunately I don't really have that choice no one I have talked to hear will pull the engine from the truck and put it in the car. plus how am i supposed to learn by letting someone else do it
You learn by reading books, articles, etc. You learn from others before you jump into something that you have no idea what you're doing.
Car: 1989 Camaro RS--
Engine: MPFI
Motormite/Clutch Pilot Bearing
Would this help????
For your 1989 Chevrolet Camaro 2.8L FI 6cyl
Price: $2.99
Part Number: 14647
AVAILABILITY:
STORE PICK UP
SPECIAL ORDER
Visit your local store to special order.
SHIP TO HOME
AVAILABLE
Ships within 2 business days.
ADD TO CART
Eligible for FREE 2-Day Shipping
learn more | sign in
Part Number:14647Weight:0.05 lbsNotes:Pilot bushingType:AInside Diameter:0.594 in.Outside Diameter:0.828 in.Length:0.746 in.Shipping Information:Overnight and Two Day shipping are not available for PO Box, APO/FPO/DPO or US Territory addresses.
Would this help????
Price: $2.99
Part Number: 14647
AVAILABILITY:
STORE PICK UP
SPECIAL ORDER
SHIP TO HOME
AVAILABLE
ADD TO CART
Car: 1986 firebird
Engine: 2.8l v6
Yes i understand that is how you learn that is y i am here asking questions, but like i said i dont have the option of taking it somewhere so i will figure it out and when you dont have someone to teach you you figure out how to do it yourself either by doing it and it working or by trial and error
Car: 1982 Firebird Base
Engine: 2.8L V6
Axle/Gears: Stock
It should be an easy swap....
Pay close attention to EVERYTHING, and if ANYTHING is different, use the one from the F-body instead of the one from the S-10.
Depending on different years, you may want to swap exhaust manifolds, intakes, carb/throttle body from the bad motor to the good one.
When in doubt, stick to the part from the car.
