can i put a2.8 carb intake on 2.8 mulitport motor
Old Aug 10, 2012 | 10:35 PM
russellj0's Avatar
Im trying to build my wife a 86 firebird for a derby car. It has a2.8 multiport in it and I have a 2.8 carbon intake I am wanting to put on it. I was told it would not work unless I change heads also. Is this true. Any help would be greatly appreciated. Thanks
Old Aug 11, 2012 | 12:01 AM
project89's Avatar
Re: can i put a2.8 carb intake on 2.8 mulitport motor
it will bolt right one, the problem is u will ne an older vacum advance distributor to use with the carb.
without the throttle body and asorted sensor the ecm will not give the correct amount of spark advance with the carb/intake ontop
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
midge54
Dec 27, 2019 04:14 PM
86IROC112
Aug 17, 2015 02:00 PM
cstrobel65
Aug 15, 2015 10:19 AM
