2.8 firebird fires out of the intake manifold
Old Sep 11, 2012 | 12:56 PM
hicadula314's Avatar
Alright, i recently did a head gasket, water pump, and timing chain gasket replace on a friends 89 2.8 firebird. got it all put back together, and now when cranking it "front fires" basically backfiring from the intake manifold where the air box hooks in. any help would be much appreciated as this has been an 11 day project now and i want it out of my garage to work on my new to me Jeep
Old Sep 11, 2012 | 01:27 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: 2.8 firebird fires out of the intake manifold
Sounds like the distrib was put in wrong.. I would say it is a timing issue..
Old Sep 11, 2012 | 01:43 PM
Never pulled the distributor tho. And have now timed it while cranking
Old Sep 19, 2012 | 10:17 PM
nbrittenham's Avatar
Car: 1990 Firebird, 1987 Trans Am GTA
Engine: 3.1L V6, 305 V-8
I had a trans am that was doing the same thing turns out it was my timing being way off somehow. I didnt mess with mine either prior to having the problem but adjusting it fixed the issue
Posted from Thirdgen.org App for Android
Old Sep 20, 2012 | 08:51 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Make sure you put the plug wires back on the right plugs...
Old Sep 21, 2012 | 03:47 PM
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
Recheck the valve lash. If the valves are too tight they will hang open and backfire through the intake. Make sure you are timing on the number 1 cylinder, it is on the passenger side, not the driver's side like a small block.
Also, how did you do a head gasket without pulling the distributor?
ASE doc
Alternative Port EFI Intakes
Jan 12, 2020 11:35 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
theurge
Aug 21, 2015 12:46 PM
Jake_92RS
Aug 11, 2015 10:39 AM
