which rebuild kit should i get
Old Oct 13, 2012 | 03:23 PM
rchobby89's Avatar
hey guys I'm rebuilding a 3.4 for my 8 9firebird should I get a rebuild kit for the 3.4 or for the 2.8 as far as gaskets and stuff
Old Oct 13, 2012 | 11:00 PM
project89's Avatar
Re: which rebuild kit should i get
all the gaskets will be the same except the intake maifold and head gaskets
so u could order a full set for the 2.8 to make it easy then u would only have to buy a set of 3.4 headgaskets . the 2.8 headgaskets will have to small of a bore to use on the 3.4
if u order a gasket set for the 3.4 the intake manifold gaskets wont work for the 2.8 intake so then u could just order a 2.8 intake set
see which way it is cheaper to buy and just do that
Old Oct 13, 2012 | 11:13 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
I went with 2.8 gaskets for everything but the heads. Only difference is like project89 said, head gaskets. Assuming you're using the 2.8 top end.
Old Oct 14, 2012 | 09:14 AM
rchobby89's Avatar
ya thanks guys so ill order it for the 3.4 and I only need intake gaskets the water pumps are the same on both correct I dnt have the 2.8 out I'm rebuilding the 3.4 with new everything before I put it in and find something wroung with it also is there any way I could use the 3.4 oil pan cause my 2.8 has a big dent in it thanks agian
Old Oct 15, 2012 | 04:11 PM
rchobby89's Avatar
will a 2.8 rebuild kit work on the 3.4 guys I'm buying a re-ring kit so are the rings going to be the same because the 2.8 rebuild kit is 80 cheaper thanks
Old Oct 15, 2012 | 04:53 PM
project89's Avatar
no the 2.8 piston is smaller if u are getting a re-ring kit u have to get one for the 3.4
Old Oct 15, 2012 | 08:42 PM
rchobby89's Avatar
k thank you
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
tonys91rs
Oct 10, 2015 03:31 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
