cold start injector wire color matching
Old Nov 22, 2012 | 01:23 PM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
Harness is tan and brown.
Plug I got from the junkyard is purple and brown.
Chiltons shows purple and tan.
What do you all think? Hook up brown to brown and purple to tan?
My old plug is gone. I think it's ok either way, but I'm not completely sure.
Old Nov 22, 2012 | 05:02 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: cold start injector wire color matching
Purple to purple and whatever else to whatever else. Purple is the power wire coming from the CRANK circuit. If you do it backwards, the CSI isn't going to open.
Old Nov 23, 2012 | 02:45 PM
Engine: 3.4
Hmmm. I'll double check, but the two wires coming from the harness are tan and brown.
I'll search my toolbox some more and see if I didn't save the broken connector that I cut off. Or just extend the wires so I can get to them after installing the distributor, and then I can test for voltage while cranking it.
Old Nov 23, 2012 | 09:37 PM
Engine: 2.7L V6
Axle/Gears: 4.41
The one wire is probably dirty. Only 2 wire colors in the circuit, purple and tan (power wire running to underdash connector is purple with white stripe, but you don't need to worry about that ATM).
http://92b4crs.tripod.com/86wiring/dia-pics/21-6.jpg
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
apie2546
Aug 10, 2015 05:43 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
