power steering
Old Dec 12, 2012 | 05:58 PM
ktmracerx009's Avatar
Car: 1987 Camaro
Engine: 2.8 tpi
Transmission: 5 speed
power steering
hey guys i have a power steering leak
how much fluid does it hold so i know mow much to buy
Old Dec 22, 2012 | 04:56 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: power steering
I'm probably really late with this, but it would depend on where your leak is coming from. If it's the pump or steering box, you're gonna lose a lot of fluid when you replace it and will need a couple quarts. If it's not the pump or steering box, you can start with a pint, and go from there, just don't let the pump reservoir drain while you're doing your work. Put a hose over the line coming from the pump with a screw/bolt in the end of it to keep it from leaking out.
Old Dec 22, 2012 | 10:11 PM
91CamaroRS101's Avatar
Car: 91 Camaro RS
Engine: 3.1 V6
Transmission: 700R4/4L60E
Re: power steering
Really, I do not know how much fluid it holds, but usually cars have a oil stick on the cap where it reads cold and hot. Best thing to do is add and check frequently. I would get that replaces ASAP if it is leaking badly. Although, never drain the system. The pump will go out and could wreck your steering box due to lack of lubrication. I would price new hoses and replace it. Hoses are still cheaper than a pump and steering box.
Old Dec 22, 2012 | 10:53 PM
drdave88's Avatar
Engine: 6.0L
Re: power steering
Originally Posted by 91CamaroRS101
Really, I do not know how much fluid it holds, but usually cars have a oil stick on the cap where it reads cold and hot. Best thing to do is add and check frequently. I would get that replaces ASAP if it is leaking badly. Although, never drain the system. The pump will go out and could wreck your rack and pinion due to lack of lubrication. I would price new hoses and replace it. Hoses are still cheaper than a pump and rack and pinion.
Not to sound like a jerk, but....you may wanna take a peek under the hood of your car, and under the front steering/suspension of it......... Our Camaros/Firebirds do NOT, and have NEVER HAD rack and pinion steering. Unless someone modded it into yours, you may wanna hit up the Haynes/Chiltons manuals before you get working on yours.
Old Dec 23, 2012 | 07:22 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: power steering
Just buy a quart of PS fluid.
If its the pump shaft leaking, the pump itself is cheap and easy to replace, just take your time not to F up the threaded fitting or youll be getting a new PS hose too. ask me how I know.
Old Dec 23, 2012 | 07:12 PM
Car: 91 Camaro RS
Engine: 3.1 V6
Re: power steering
Oh, I know I realized that. I'm used to modern day cars because I always work at them at the shop. Yeah, I know it is definitely not a rack and pinion. I have a rack and pinion to replace for a customer. So, it was on my mind. Yeah, I'm sorry about it.
Squeaky8791
Feb 5, 2020 08:29 PM
Vintageracer
Jan 10, 2020 05:33 PM
Chuck84TA
Jul 15, 2016 09:05 PM
evilstuie
Apr 14, 2016 08:52 PM
deracer
Apr 11, 2016 12:04 AM
