Cheap Ebay turbos for the V6...
Car: 87 IROCZ Z28
Engine: 3900V6 GT4088 intecooled
Transmission: TH350
Axle/Gears: 3.45 MSF Spool
I'm thinking of testing one out on my Fiero.
Thinking this on a 3500V6.
http://www.ebay.com.au/itm/new-GT30-...-/181048034471
56.6mm turbo, T3 exhaust.
Should work alright I suppose, low boost non-intercooled.
Anyone else know of any CHEAP CHEAP ebay turbos ?
This is more of a test. I know all about "you get what you pay for", I have owned 2 other turbos and they never gave me a lick of trouble, both Garretts. It would just be funny if I can get 40,000 miles on a 160$ turbo. haha. Anyone try these turbos ?
I've done some googling and it would appear a TON of people have had good results.
Comments ?
Comments ?
Re: Cheap Ebay turbos for the V6...
I'm curious honestly as well on this and how well they would work as I know of some cheap beaters that would be quite interesting with a setup if they work and work ok that is
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
fasteddi and I bought the gt3582r, he had his running just before the white sh*t dropped. mine is still in the box. not sure you would want to pay all that shipping though.
http://www.ebay.com/itm/GODSPEED-T3-...sories&vxp=mtr
to smal mars 52mm/62.5 mm exducer the first turbo fasteddi ran maxed out at around 16 psi on the iron headed 3.1 and that turbo was 57/72mm
for a relativly low powerd setup 350 hp that turbo would be great and is 118$ shipped
the next step up would be the 52/76mm t3/t4 hybrid with the 3 inch compressor cover
after that u have the gt3076 which i run a pair on my iroc 57/76mm 139$ shipped
and last but not least the best bang for the buck for a 3500 prolly is the 250$ 61/82mm gt3582
and if u think u could spool it the ebay gt45 turbo 70/106mm 83mm turbine and t4 1.05 ex housing for 299 shipped but the gt45 is a big *** turbo
i would use this turbo before the one u listed mars
http://www.ebay.com/itm/T3-T4-Hybrid...99b176&vxp=mtr
thats the same turbo i used to run on my 3.1
heres some pics to give u an idea of just how large the gt45 is
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
I had a 118 dollar one and it was pretty good.
Now im on the Gt3582 godspeed one. It was 275 bucks to the door. Im not sure on how low of a price your looking for but dave linked some good stuff for the price.
Small one was the cheepest one. Got me into the low/mid 13's pretty easy. Then the other is the godspeed one.
Cheep one But the price went up a few bucks. I believe this is the correct one I had.
http://www.ebay.com/itm/T3-T4-T04E-T...item4cefdb413e
The godspeed one that me and 34blazer have.
http://www.ebay.com/itm/GODSPEED-T3-...b35b72&vxp=mtr
Car: 87 IROCZ Z28
Transmission: TH350
GT 45 is WAY WAY too big.
The cheapest I can find that GT35 one is here, this is a 61/82mm, like the ones you guys posted up: Would be 325$ to my door.
http://www.ebay.com/itm/GT35-Turbo-C...sories&vxp=mtr
I kind of think it's a little large. I want very little lag. This one here got my interest as well it is a little smaller. Looks like a 3", 2" discharge inlet compressor with a 57/75mm wheel. : $330 to my door. It's sized VERY similar to a GT3076 by the looks of it.
http://www.ebay.ca/itm/T3-T3-60-1-UN...1552c4&vxp=mtr
My ideal turbo would be a GT3076, but I can't seem to find cheap ones.
I want a 4 bolt disharge flange (not the 5 bolt) with T3 inlet I already flanges that's why. and i don't want a built in W/G cause there will be no room for that arrangement.
Where did you get your 3076 ???
the only thing is the seller does not know his stock i got 2 57/76mm turbos from him and fast ordered from the same seller and got a 57/72mm unit
watch fasteddis turbo video with the gt3582 it spools up dam fast with only 3.1L with 3.5L i bet u it would be damn near perfect
Car: 87 IROCZ Z28
Transmission: TH350
Where is this video you speak of ?
Yeah, I want a 57/76 but it's looking alot like GT35.
if that dont work click this link
Car: 1991 Camaro RS
The boost is pretty agressive on this turbo. Not laggy at all.
Why cant you get a gt3582 like me and blazer have for 275 shipped to your door? Does it cost more to ship it to canada?? Ive never really looked into what it cost to ship across the border.
The turbo I have is a 4 bolt 3 inch exhaust discharge.
4 inch intake charge. 2 1/2 inch discharge air.
Car: 87 IROCZ Z28
Transmission: TH350
Yeah I will likely get the GT35.
It spools around 4600 in that Vid, hopefully I can do it under 4000 with a 3.5L
Thanks guys !
Thanks guys !
my 60-1 spools up instantly from a roll and barley any lag from a dead stop let me see if i can find a video
turbo made 2 psi at about 2,900 in his video the gauges/datalog is a split second earlier then the video, by 3,500 its making alot of boost to hard to see the number
heres the video of mine keep in mind my 60-1 has a larger turbine wheel and housing then a gt3582, i had a t3 .84 housing on mine, any smaller would have resulted in uncontrollable wheel spin
http://www.streetfire.net/video/just...nd_162499.htm#
Car: 1991 Camaro RS
It spools faster, I just never could floor it from a slow cost or stop because of the crappy open rear end.
This may show it better. This was the first time I ever made boost with the new turbo.
Car: 1986 sports coupe, 1984 F41
Engine: 3.8L Turbo SFI, stock 305
Transmission: 700 R4, 700 R4
Axle/Gears: 3.42:1, 3.08:1
Car: 87 IROCZ Z28
Transmission: TH350
Do any of you guys know of a decent BOV for cheap ?? ( I DON;'T want anything with an alum. flange cause I'm not equipped to weld alum.)
I know I'm getting another 38mm EMUSA wastegate (cause I'm using 2 of these on my Camaro and they are very nice for only 60$) I am using the 2 bolt flange type. They are damn good pieces for the price. adjustable from 4 to 10 psi
So, gt35 it is.. I'll order one up soon and get to installing everything.
I was cleaning out my garage and found all kinds of stuff so figured WTF, lets turbo this car, lol.
42# injectros, 2 bar map (I will run the 8F turbo grand prix code mask), T3 flanges (inlet and disharge, gaskets) I have all kinds of mandrel bends and siliocne couplers. My oil pan already has a #10 drain fitting, oil lines for feed and drain, I figured out a hotside using Stock FWD 3100V6 manifolds.
ebay rfl knockoff it comes with both a steel and aluminum weldflange i use these exclusivly .
be aware its a really loud bov
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
wonder if any of the good cheap ones can be used as a wet turbo, ya know, suck through; not blow.
Car: 1991 Camaro RS
im not sure... that would be intresting to see how fast it sandblasts the impeller.
Car: check
Engine: check
Transmission: check
When we ship outside of the US we use either Priority Mail or Express Mail International via USPS. Both have tracking and the delivery times are good.
RBob.
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
^This. I shipped tail lights to Spain through USPS and it was maybe $35.
Car: 87 IROCZ Z28
Transmission: TH350
OK, I just started to get a couple parts.
QUESTION :
Are you guys using a restrictor in your GT35 turbos ??
QUESTION :
-3 feed is best -4 is fine
do a -3 with no restrictor
the gt35 is a journal bearing turbo even with a -4 it shouldnt need a restictor unless u have really high oil presure
Car: 1991 Camaro RS
Ive got a 4an going in. 60psi oil pressure hot idle 80+psi WOT..if the guage is right.
No issues so far
No issues so far
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
this is the turbo I keep on my ebay watch list
http://bit.ly/S13OiJ
Car: 1991 Camaro RS
Else then the internal wastegate and V band, I think thats the same turbo I had on my car originally. Its a good turbo for our engines for the price.
yeah its the same turbo u started with fast, only difference is it has the internal wg
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
could of used it last night, I know I could of pulled away from the maroon but throughly leaving them behind is better........
u guys are close if fast still has his under k ypipe see if he will sell it to ya ,
if u use that turbo u will need atleast some larger injectors, afpr and a tune ,though by being a 2.8 car u can get away with about 7-12 psi with the stock heads and cam on it
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Im really not gonna do allot, no way I could change the stock Y pipe, whole engine would need pulled to drill out those studs. Id like to treat it like putting on a fagoel blower, no changes over stock cept maybe a timing bump to see what it can do as is.
Car: 1991 Camaro RS
Ive got some piping, a AFRP, and those GN injectors stil. Many 2 1/2 inch couplers too. Including 90*'s
Hay guy's i would like to share something with you which is that I'm curious honestly as well on this and how well they would work as I know of some cheap beaters that would be quite interesting with a setup if they work and work.....
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Anyone wanting a great ignition upgrade , then check out Bob Bailey's TR6
Car: 1991 Camaro RS
Thats a pretty slick set up.
If you wana see how little lag there is on my turbo (GT3582) just open this up in excel after you unzip the file. I still can get a lick of traction on the street but damm thing has almost instant boost when I go WOT.
This logg is way to rich though, so there is no point in telling me that. And for some reason when I shift manually I feel the need to shift at 6400 or so rpms...lol hope that doesnt catch up with me. Hense why its so rich at that point(I never tuned it much for that area).
Car: 1991 Camaro RS
I just know it shifts hard from 2nd to 3rd when its reving 6300 or so. Seems to pull harder the higher I go. It still drops RPM's when shifting so the trans is doing ok for now i suppose. Good enough considering I cant afford the TH swap yet.
It definitly needs tuned better though, as I know im leaving alot on the table at this point.
Nice turbo lag though dont you think dave?? Much better then the last engine/turbo set up.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
mine likes to pull to 6000 and beyond as is, doesn't stop asking for more RPM.
it will prolly make power till around 67-6,900 with that gt3582 and 260 cam
the gears are masking the converter issues for now since its taken some load off the engine
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Car: 87 IROCZ Z28
Transmission: TH350
Ahhh, well this is no longer going to be an ebay build...
Found a used precision billet 5858 for sale locally and picked it up for cheaper then an ebay unit.
I has a .63 T3 turbine, and the E compressor - 3"in/2"out
Not quite as large as a GT35, but at 58mm, it will hopefully spool nice and quick.
Build thread imminent.
Engine: LZ9????
Transmission: 2004R
Car: 2006 Cobalt SS/SC
Engine: LSJ
Transmission: F35 MU3
Axle/Gears: 4.05
e3pres
Sep 9, 2015 01:51 PM
