Coolant leak, need to replace gaskets to fix. What is the name of this part (pics).
Old Apr 20, 2013 | 11:12 AM
  #51
Stewie's Avatar
Car: 1992 Firebird
Engine: 3.1L
Transmission: Manual T5
Axle/Gears: Stock
Re: Coolant leak, need to replace gaskets to fix. What is the name of this part (pics
Originally Posted by ItstillaV6
When you refill the cooling system, fill the overflow bottle and radiator. Once they are filled, you should see a hose, on the passenger side of the engine bay, to your water pump. It'll be located under you alternator, and in front of your right exhaust manifold. There is a black plastic cap. Unscrew it and begin "priming" the water pump. This also fills your heater core. When the level if at the top, of the cap threads, place the cap back on.
When I did my water pump, I didn't fill the rubber line, to my pump and heater core. Within a few minutes, my temp gauge had shot up the red area. When I let it cool, I popped that cap, filled it up, and that took care of the problem..
ItstillaV6, thanks for that bit of wisdom on how to change engine coolant. I've got to do that soon for my car and didn't know how to prime the water pump & heater. Probably saved me a lot of time trying to find out why the engine would over heat just from changing coolant. With other vehicle makes, after changing coolant, I turned on the heater which forced water into that part of the coolant system.
Old Apr 20, 2013 | 11:19 AM
  #52
Stewie's Avatar
Car: 1992 Firebird
Engine: 3.1L
Axle/Gears: Stock
Sorry, double post. I'm an airhead.
1992 Trans Am
May 10, 2023 07:19 PM
TheExaminer
Aug 26, 2015 04:59 PM
MY87LT
Aug 17, 2015 08:43 AM
mizz0313
Aug 12, 2015 06:45 AM
1nastygta
Aug 8, 2015 07:38 PM
