Pictures of 2.8 headers installed. Please.
Old Feb 11, 2013 | 12:06 AM
crazybird's Avatar
Car: 1987 firebird
Anyone got pics? or any war stories or tips on installing yourself.
Old Feb 12, 2013 | 06:50 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Pictures of 2.8 headers installed. Please.
https://www.thirdgen.org/forums/post...0-post149.html
No, the engine isn't finished yet. I only got it to crank over with the starter last Friday. I still need to delete the PS EGR port parts and weld the 3100 EGR tube to the #2 primary.
The installation is MUCH easier with bolts than the studs I'm using. The driver's side is a pain. You WILL need to bend the oil dipstick tube to get the header flange between it and the cylinder head.
And, if you have a T-5, the slave cylinder heat shield gets removed, the slave and connecting tube get heat shielded, and you will need washers and nuts to reinstall the slave cylinder to the bellhousing. The slave heat shield WILL prevent the header from lining up (#6 primary hits on it).
hectre13
Sep 8, 2015 03:38 PM
cougar20th
Aug 27, 2015 08:04 AM
chubsworth
Aug 26, 2015 02:34 AM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
