Hesitating and surging problem help please
Old Mar 1, 2013 | 01:40 AM
Shane Shaffer's Avatar
I have a 91 camaro rs 3.1l v6 and lately been having an issue when it's cold it runs fine but after its at normal temp every time I go to give it gas it pretty much spits n sputters till its up to speed but its only when it's warm it idles fine only does it on acceleration I just replaced fuel pump fuel filter plugs wires cap n rotor and the control module so if anyone with any suggestions would be great I was thinkin tps or plugged cat but the only code that is flashing is dtc 43 eletronic spark control failure and I was reading that that is the knock sensor if I'm wrong please correct me n if u know What dtc 43 is I would like to know thank you
Old Mar 3, 2013 | 11:35 AM
copyfixr's Avatar
Car: 88 Camaro
Engine: 2.8v6
Transmission: 700 R4
Re: Hesitating and surging problem help please
I had a similar issue with my son's 88 2.8. Ran ok when we first got it but went down hill the more work we did on it. It ran the worst after re replaced the injectors and all the plenum and intake gasktes. After a lot of head scratching, we discovered we had a plugged cat and muffler. The car would start up and idle fine cold, but once it warmed up a bit had a bad surge in the idle and would pop and backfire in the intake. We removed the O2 sensor to test it and let it breath a little more and it got a lot better so new exhaust went on. After that we did the idle/minimum air adjustment and it runs like a champ.
Old Mar 3, 2013 | 01:06 PM
Ok thank u so much and i when it is acting up I can hear the backfire and the cat so ill repeat what u have done and go from there thank you again kind sir
Old Mar 3, 2013 | 01:49 PM
copyfixr's Avatar
Car: 88 Camaro
Engine: 2.8v6
No problem. I have gotten a ton of help from other guys here. Just trying to pay it forward. I hope it helps. Try removing the o2 sensor and see how it idles. Get a new one and a thread chaser before you start ecsuse there is a fair chance you will have trouble Removing the old one. Cheap part to replace. Good luck.
Old Mar 3, 2013 | 02:15 PM
Ok will do thank you again ill post the results when I get to it
Old May 17, 2013 | 10:16 PM
chikenbag's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.1L V6
If you're getting a knock sensor error then replace the knock sensor. When I first got my car, out of nowhere i started losing power and it threw the knock sensor code. If its not the knock sensor or the cat like copyfixr suggested I would also check the coolant temp sensor.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
