Under drive pulleys
Old Mar 6, 2013 | 02:50 AM
KG427KG427's Avatar
Car: 1991 camaro
Engine: 3.1L V6 dynomax exhaust
Transmission: 700r4 auto
Axle/Gears: 89 iroc-z 9bolt disc+posi 3.27
Under drive pulleys
Hey I have a 91 Camaro 3.1 engine and I'm looking at getting
ASP Underdrive Pulleys
What do u think ?
I'm looking to improve my gas mileage I do have a sound system but I have a higher end battery 300$ ill get more info on it, my alternator is stock should I upgrade that 2?
Old Mar 6, 2013 | 04:51 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: Under drive pulleys
underdrive pulleys help a tad but for the cost its up to you. If the stock alt works fine, I wouldnt bother getting a new one.
Old Mar 6, 2013 | 10:20 AM
KG427KG427's Avatar
Car: 1991 camaro
So keep stock alternator and get get the underdrivepulley
Old Mar 6, 2013 | 03:29 PM
fasteddi's Avatar
Car: 1991 Camaro RS
If you want to. Its all up to you. Personally, I would spend it else where as I had them at one time and saw no noticible real world gain. BTW i got the chips. Im working on them now.
Old Mar 6, 2013 | 03:56 PM
KG427KG427's Avatar
Car: 1991 camaro
Ok great man I order more chips. Well other than al drive shift and pulleys where else would u spend your money.
Old Mar 6, 2013 | 04:57 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Your chips are fried off and good to go. Heres a great link on how to easily put in that g1 adapter you have along with the chips.
http://support.moates.net/g1/
Open up that link and print out the pages. It make installing for a first timer a breeze.
Old Mar 6, 2013 | 05:00 PM
KG427KG427's Avatar
Car: 1991 camaro
Ok perfect thank you again. Can't wait to get them installed.
Old Mar 6, 2013 | 06:35 PM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Not to hijack, but since you know how to burn chips, do you know how to burn a chip that has all settings stock, but gets rid of the VATS? My VATS works fine now, but who knows down the road.
Old Mar 6, 2013 | 06:37 PM
2007xl50's Avatar
Engine: LB9/3.1
BTW, my old 90 Stang 5.0 had the full March UDP's on it and I hated them. The ALT did not charge much at idle and at night with all the lights on the light got very dim at idle. IMO pullys are not worth the money or time to install them, infact if I would not have sold the car I would have put a new long block 306 in it and went back to all stock pullys.
Old Mar 26, 2013 | 08:32 AM
KG427KG427's Avatar
Car: 1991 camaro
Great man the chip was amazing probably gave me 3-4 mpg plus 1.5~ mpg for Alu driveshaft, also the dual snorkel with KN filters, 16x8 alloy wheels,
new: stock replacement
Egr
Radiator
o2
Water pump
Ignition module
Fuel injectors
Timing chain
Thermostat
Motor for radiator fan
Motor for AC fan
Alternator
Harmonic balance
Dynomax 2.5 inch exhaust system
Koni struts shocks
Posi 3.27 gear ratio 4 disc
Stock rotors break cables
36.7 mpg getting over 390 miles on a tank .
What can I do besides weight..
I need legal headers for California any more help please ??
Old Mar 26, 2013 | 10:15 AM
Fallen2603's Avatar
Car: 2006 Cobalt SS/SC
Engine: LSJ
Transmission: F35 MU3
Axle/Gears: 4.05
Find some way to add EGR to the Pace Setter headers...?
Old Mar 26, 2013 | 04:12 PM
fasteddi's Avatar
Car: 1991 Camaro RS
I probly could have tuned a few mpgs more at best. Its at the top of the field of thirdgens to get 35mpg's+ It would have been so much easier if you could of datalogged it so we could push it.
But for the headers..... I dont believe anyone sells headers that are cal. legal. You would have to weld up a flang of somesort to incorporate the EGR valve like fallen2603 said.
But what do you want??? More horsepower??? Your really not going to get much more mpgs.
Old Mar 26, 2013 | 05:49 PM
project89's Avatar
hes right 35mpg is really pushing it theres a few tricks u can do to get a lil more out of it though.
u can lighten the axle flanges , get the lightest rim and tire combo u can , lower the car a lil to decrease drag , drive with the windows up
other then that a small turbo would help increase milage some but being in cali thats pretty much out of the question for u as its not smog legal
Old Mar 26, 2013 | 09:27 PM
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
Over 35 MPG in a '91 Camaro is pretty damn good. Hell, my stock '06 Cobalt SS/SC gets 31 MPG on a good day with tons of highway driving.
Cut the weight where you can, or toss things out of the car that you're comfortable with tossing out. Other than that...not much else would I do.
Old Mar 26, 2013 | 10:57 PM
KG427KG427's Avatar
Car: 1991 camaro
The only thing that would be better instead of driving 65mph getting 35mpg would be driving 71mph getting the same.
And I guess I'll wait and put the 260 grind delta cam on the 3.4 block. The 3.4 should get a little better mpg 2. Not looking for HP just a good commuter
Old Mar 27, 2013 | 05:05 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Your rear end gears are going to affect your high MPH MPG's. 2.73's would probly help but then the car would seem alot under acceleration.
Old Mar 27, 2013 | 01:49 PM
project89's Avatar
2:73's will kill gas milage since he would have to step so far on the gas to get the car to move not to emention it would take more throttle to keep the car at highway speeds
Old Mar 27, 2013 | 03:01 PM
fasteddi's Avatar
Car: 1991 Camaro RS
The gears would help at crusing highway mpgs. Rpms would be about 500 lower. But your right it would hurt the mpgs to get up to speed and possibly hold the mph if its hilly and not flat as a board like im use to here in Ohio.
Old Mar 27, 2013 | 09:13 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
If we're still gonna talk about the original topic, I installed that U/D pulley on my crank, it didn't make any noticeable difference at all. Considering the cost, I would save the money and put it somewhere else. If you want to brag and can afford it, well then go for it.
Old Mar 27, 2013 | 10:04 PM
KG427KG427's Avatar
Car: 1991 camaro
Where else do I spend my money? Brag? Glad I didn't buy the pulleys.
Thanks for the heads up on that sir.
Old Mar 28, 2013 | 02:00 PM
drdave88's Avatar
Engine: 6.0L
You can spend it on all different kinds of things; depends on what you have done already. Plug wires, 180 t-stat, CAI, and if you stick a bit more with it, the list keeps going. check out the sticky at the top for parts.
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
Navy8125
Aug 22, 2015 07:13 PM
mcquigg
Aug 13, 2015 02:26 PM
