Would injectors work with painless wiring system
Old Apr 6, 2013 | 03:28 AM
Speedrookie's Avatar
Car: 1985 camaro
Engine: 2.8l v6
Transmission: 5-Speed
I just bought a 1985 2.8l v6 Camaro and looked under the hood and saw that most of the wiring was shot. So I am going to buy the painless wiring switch panels .I just wanted to know if I use the switch panels for the fuel pump and ignition system would the fuel injectors automatically kick in or if not what do I need to do.
http://www.summitracing.com/parts/prf-50301/media------ the switch panels
Old Apr 6, 2013 | 11:15 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Would injectors work with painless wiring system
I'm not sure you understand the purpose of those switch panels, They don't replace the underhood wiring harness, at least not the engine control harness.
What's bad about your existing harness?
Old Apr 6, 2013 | 12:17 PM
Car: 1985 camaro
Engine: 2.8l v6
It looks like a family of rats got in there and chewed up most wires some wires are corroded and most relays are corroded
I was thinking I could just send power to the fuel pump and power to the ignition system to start the engine, but without the kit the when I turn the key on the engine does spin over.
Old Apr 6, 2013 | 12:29 PM
Since this is posted in a few forums, I will lock this one.
Next time post in a single forum.
You'd be better off repairing what is there, than trying to replace it with something completely different.
MustangBeater20
Oct 29, 2022 09:20 PM
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Jae992
Aug 27, 2015 09:07 AM
squiggy2
Aug 9, 2015 09:30 PM
