Code 32 at normal speed but goes away when going uphill?
Old Apr 16, 2013 | 04:05 PM
GageBrand's Avatar
Car: 1985 Iroc-z28
Engine: 5.7l TPI
Axle/Gears: Stock
Code 32 is EGR failure, but the code goes away when I am either accelerating up a hill or sometimes it goes away at highway speeds, I have tried replacing the valve but the code still came up after clearing it. I took the sensor back and put the old one back on. Any reason behind this or troubleshooting?
Old Apr 16, 2013 | 05:36 PM
Cadaver_Puncher's Avatar
Car: 92 Camaro rs ( mostly stock for now
Engine: 3.1 v6
Transmission: 700r4 with a b&m megashifter.
Axle/Gears: whatever came stock. wanna posi tho
Re: Code 32 at normal speed but goes away when going uphill?
Did you reset the ECM after you installed the new part?
Old Apr 16, 2013 | 06:28 PM
GageBrand's Avatar
Car: 1985 Iroc-z28
Engine: 5.7l TPI
Axle/Gears: Stock
Yes I did twice, I also replaced the MAP sensor and that code went away but the EGR code was still there so it is clearly an EGR problem still
chazman
Aug 28, 2018 03:25 PM
NiG
Oct 11, 2015 08:42 PM
destroyerwes
Aug 26, 2015 08:17 PM
chazman
Aug 22, 2015 02:01 PM
