Belt length?
Old Apr 16, 2013 | 08:33 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Belt length?
Probably a dumb question, but since I've never had to do it before...
What's the easiest way to measure for a new belt? No, I can't use one of my stock belts, but I can cut one up to use as a measuring device (since nobody apparently wants an almost-new non-AIR with A/C belt!).
Measuring for the belt is one of the last half-dozen things left to do in the front of the car...
Old Apr 17, 2013 | 08:00 AM
mcrandrz's Avatar
Car: 1991 camaro rs
Engine: 3.1 - looking to upgrade to 3400 hy
Axle/Gears: Stock? Lol
Take a string around the pulleys. Then mark it and measure it.
Posted from Thirdgen.org App for Android
Old Apr 17, 2013 | 07:46 PM
Cadaver_Puncher's Avatar
Car: 92 Camaro rs ( mostly stock for now
Engine: 3.1 v6
Transmission: 700r4 with a b&m megashifter.
Axle/Gears: whatever came stock. wanna posi tho
Re: Belt length?
Well damn if I had money I'd take the belt. It's for access but no air pump right? Problem is I don't get my check til the first. If I end up taking my air pump off ...other than removing pump and changing belt, the hole in the exhaust would take a 1/2" pipe plug? I have no access to a welder.
Old Apr 17, 2013 | 08:45 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: Belt length?
I have 2 belts...
1. 915K6, non-AIR, with A/C and power steering, serpentine
2. 815K6, non-AIR, non-A/C, serpentine
915K6 didn't have much time on it, IIRC, before I finally ditched the A/C compressor (only remaining part of the A/C left for a while), and the 815K6 is almost new (bought to replace the other 815 which I thought was squealing but it turned out to be the water pump, again ).
I need to get the PS pulley before I can measure for the replacement belt, unfortunately.
Old Apr 17, 2013 | 09:10 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: Belt length?
I had to measure mine when I put an underdrive pulley on mine after deleting a couple of other accessories. As stated above, take a rope/string and route it around all the pulleys. Make sure you keep it tight and then measure the length. You'll want to subtract an inch and a half or so from that. Take that measurement down to ______ parts store and get a belt around that length. You'll want to buy a few belts within that range, since you won't be spot on. Find the one that fits best and return the others. It took me a few tries, but it seems to work the best if you need a custom length belt.
MrPackstin
Oct 25, 2017 08:09 PM
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
SRKLEGIN
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
