200mph
Old May 20, 2013 | 02:02 PM
  #51
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: 200mph
My suggestion, which I plan on following myself, is get the car and yourself ready to pass the tech inspection. I watched a few being done and it is very extensive. Then run with the engine you have at the lower speed runs which you have to do before going really fast. Also, I think 150 is the point at which requirements change big time. All glass replaced by Lexan, parachute? etc.etc. I don't know how many trips to the flats it takes to get from scratch to 150 then to 200. Could be several.
Old May 20, 2013 | 02:05 PM
  #52
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: 200mph
^ then on the last run put your foot into it and go WOT till there is no road left and just use on board GPS to back up your speeds, F getting into some book.......
Old May 20, 2013 | 02:14 PM
  #53
danclemts's Avatar
Car: 1985 Volvo turbodiesel
Engine: 1989 305 TPI in the Volvo
Transmission: 1990 700r4
Axle/Gears: 3.73 Dana 30
Re: 200mph
Remember, aero drag cubes as speed doubles, much harder to go from 150 to 160 then 110-120. Aero improvements will be a huge benefit at higher speeds.
Also get a really good roll cage etc, but all that will be spelled out in the rule book. You're gonna need to check and upgrade a lot of stuff to go that fast safely, Good luck
Old May 20, 2013 | 04:27 PM
  #54
project89's Avatar
Re: 200mph
Originally Posted by Six_Shooter
If you're looking at a 4.3, just go V8 and then you will have the ability to make the power naturally aspirated like you want to.
I don't know why people are assuming this will be a street car. When I hear "200 MPH 3rd gen" I think purpose built car that will only see duty on the flats.
a cheap turboed small block chevy will go 200 mph no problems.
hell my whole turbo build was under 2,300 bucks and will go 150 ish in the 1/4 mile
Old May 20, 2013 | 04:39 PM
  #55
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Re: 200mph
I've been told by a couple of folks who've done it that power isn't always the biggest issue unless you're seriously chasing a record. It's prepping the car and yourself and having enough money to do it! And not losing your nerve or concentration when you need it most. Probably why you have to start out 'slow'.
Old May 20, 2013 | 06:54 PM
  #56
oil pan 4's Avatar
Car: 89 Firebird
Re: 200mph
Engine power isn't the way to approch this.
You need lots of aero mods.
http://ecomodder.com/forum/showthrea...aro-23526.html
http://ecomodder.com/forum/aerodynamics.html
Old May 20, 2013 | 07:12 PM
  #57
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: 200mph
Your right he needs some good aero mods. But to get a 2.8L n/a to 150 mph plus...he's going to need to approach the engine mods pretty hard. There's a lot of things to look at.
Btw when's the last time the OP was on this thread?
Old May 20, 2013 | 07:54 PM
  #58
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: 200mph
All of the aero mods in the world will not make up for a lack of horsepower.
Horsepower is still quite a key element in this equation.
Old May 20, 2013 | 08:09 PM
  #59
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: 200mph
Bingo.
Old May 20, 2013 | 09:07 PM
  #60
oil pan 4's Avatar
Car: 89 Firebird
Re: 200mph
Yeah most people don't understand that when you double speed the horsepower requirement goes up by about 8x.
Here is a little wright up I did on going over hills, aero drag and rolling resistance effect driving.
http://www.dieselplace.com/forum/63-...elevation.html
Old May 21, 2013 | 04:40 AM
  #61
project89's Avatar
Re: 200mph
if i rember correctly a 3rdgen camaro with full ground fx and standard spoiler takes 15hp to maintain 55mph on a flat road
Old May 21, 2013 | 10:32 AM
  #62
oil pan 4's Avatar
Car: 89 Firebird
Re: 200mph
That sounds about right.
Old May 21, 2013 | 10:45 AM
  #63
oil pan 4's Avatar
Car: 89 Firebird
Re: 200mph
430Hp to go 200mph. I am sure the numbers I entered were very optimistic.
http://ecomodder.com/forum/tool-aero-rolling-resistance.php?Weight=3600&WeightUnits=lbs&CRR=.008&Cd=.36&FrontalArea=21&FrontalAreaUnits=ft^2&FuelWh=33557&IceEfficiency=.22&DrivetrainEfficiency=.95&ParasiticOverhead=1000&rho=1.225&FromToStep=5-200-5
Old May 21, 2013 | 10:47 AM
  #64
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Re: 200mph
That sounds about right. This is a graph I calculated for my TA that shows the relationship between hp and speed.
Also, weight has little effect on achieving top speed on a flat surface. The benefit of going to a smaller car will be a reduction in total frontal area of the vehicle (air drag). Aerodynamics definitely plays the biggest part at high speeds.
Old Jun 4, 2013 | 02:20 PM
  #65
david86camaro's Avatar
Car: 1986 Camaro
Engine: 2.8
Re: 200mph
People here have much more experience and done the math, so I would defer to them how easy it is to achieve 200 MPH, but I will throw in my experience. Back when I was in college about 15 years ago it got my stock v6 with t5 trans up to what I would guess based on rpm's about 160 MPH with 5 people in the car plus some luggage. I think having the extra weight in the back kept the back end down, I have heard of people have issues with the back end floating at higher speeds. I felt like I had more pedal left when I hit 160, but being on a public road, I couldn't push it more. I don't think I could have got all that mass much faster.
Old Jun 4, 2013 | 02:50 PM
  #66
oil pan 4's Avatar
Car: 89 Firebird
Re: 200mph
The HP calc I used says 160mph would need about 200 horsepower.
Thats 200HP at the wheels.
Old Jun 4, 2013 | 03:02 PM
  #67
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: 200mph
while your at it, how about fixing that mile wide link that doesn't work above??????
Old Jun 4, 2013 | 03:33 PM
  #68
oil pan 4's Avatar
Car: 89 Firebird
Re: 200mph
That link must be too long for the web site to allow me to post it
shawnpepper
Jul 26, 2015 10:50 AM
yaj15
Aftermarket Product Review
Mar 28, 2012 09:03 PM
Verviticas
Jun 22, 2005 06:24 PM
porkyzilla
Jun 13, 2005 12:29 PM
porkyzilla
Jun 13, 2005 02:08 AM
