Speedometer not working and where can i find this part?
Old May 17, 2013 | 08:45 PM
Rell_1218's Avatar
Car: 1991 Chevy Camaro RS
Engine: V6 3.1L
Axle/Gears: Stock
I recently replaced the ECM and when i drove the car my speedo wasn't working also my car wasn't shifting at the right point(Auto trans). I have a leak coming from the pipe connecting to the EGR valve but i don't know where i can buy this part.
Attached Thumbnails Speedometer not working and where can i find this part?-photo.jpg
Old May 17, 2013 | 08:55 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Speedometer not working and where can i find this part?
http://parts.nalleygmc.com/showAssem...modelYear=1991
Look at the junkyard or post a ad in the classified section
Old May 17, 2013 | 09:02 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Only thing the ECM has to do with in the transmission is the torque converter clutch (before 1993, anyways). All of the other gears are related to the TV cable (the thing attached to the throttle lever on the TB by a green connector). Double check your codes and make sure you're not getting a code for the VSS (24?). Also make sure that the connections at the ECM are good (I've had terminals come out of the connectors before).
I have at least one of those EGR pipes if you need it...
Old May 17, 2013 | 09:45 PM
chikenbag's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.1L V6
here ya go buddy. the part you need
http://www.ebay.com/itm/85-92-Camaro-Firebird-2-8-3-1-V6-Stainless-Steel-EGR-Pipe-Extension-Tube-Line-/360631704169?pt=Motors_Car_Truck_Parts_Accessories&hash=item53f7531a69&vxp=mtr
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
marcusaw
Aug 10, 2015 08:13 AM
1nastygta
Aug 8, 2015 07:38 PM
guy76767
Aug 6, 2015 05:58 PM
