Coil mounting place?
Old May 21, 2013 | 07:12 PM
mcrandrz's Avatar
Car: 1991 camaro rs
Engine: 3.1 - looking to upgrade to 3400 hy
Axle/Gears: Stock? Lol
1991 camaro 3.1
I just got my msd streetfire coil in and installed it and have no problems but I've been reading that some people have problems with overheating them in the stock mounting area? Where should it go?
Is it ok in the stock mounting place?
Posted from Thirdgen.org App for Android
Old May 21, 2013 | 08:37 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: Coil mounting place?
this coil??
Its ok to leave it where it is, but id reccomend mounting it away from the manifolds a bit. Over on the firewall, just try to keep it away from the heat as much as possible so it last longer.
Old May 21, 2013 | 09:56 PM
mcrandrz's Avatar
Car: 1991 camaro rs
Yeah I got that one. I love it. Do you hav a picture of how you have yours mounted?
Old May 22, 2013 | 09:40 AM
OrangeBird's Avatar
Car: 1989 Firebird
I can show ya where mine ended up (hanging around the firewall next to the distributor) . Just make sure to run a wire from the coil's metal frame to any good ground and you know for SURE there wont be any weird radio interference or such . I seldom change the stock configuration on anything if I don't have to , but the coil mounted right over the exhaust manifold was one GM mistake that I just couldn't in good conscience not rectify .......
Old May 22, 2013 | 09:51 AM
mcrandrz's Avatar
Car: 1991 camaro rs
Do you have a picture?
Old May 22, 2013 | 10:15 AM
OrangeBird's Avatar
Car: 1989 Firebird
it's in my other post , here , i'll try it again ...
Old May 22, 2013 | 10:17 AM
OrangeBird's Avatar
Car: 1989 Firebird
It shows up for me and is called "attached thumbnails" . Maybe you can't see it cause your settings are different or something ?
Old May 22, 2013 | 01:15 PM
mcrandrz's Avatar
Car: 1991 camaro rs
I got it. How did you stretch the harness that far?
Terrell351
Jun 13, 2021 01:13 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
TheExaminer
Aug 25, 2015 07:34 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
