what size exhaust should i get put on?
Old Jun 2, 2013 | 11:04 PM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
I have a v6 with a terrible exhaust basically i have clogged catalytic converter a exhaust leak and the muffler is basically falling apart lol. so I am going to get it replaced but i want it to sound good a guy quoted me 400 hundred for a new everything but i don't know what size piping he will use. anyway i don't know what size the factory exhaust is but i was thinking of three inch but my friend was revving his bone stock engine at school one day and it sounded so good it was deep and loud. i was just wondering should i get 3 inch exhaust or 4 inch exhaust and if theres much of a difference and is one more expensive than the other any suggestions would be great Thanks
Old Jun 2, 2013 | 11:24 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Re: what size exhaust should i get put on?
Dude. No.
Old Jun 2, 2013 | 11:26 PM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
what? Are you saying no to puting exhaust on my car it needs it bad
Old Jun 2, 2013 | 11:27 PM
rfoster23g's Avatar
Car: 92 camaro
Engine: 5.7l 350
Transmission: t5
their is ti much backpressure from the clogged cat cuasing the engine to stuter at low speeds
Old Jun 2, 2013 | 11:35 PM
Car: 1991 Firebird
Sorry, was trying to find a pic of grumpy cat saying something disparaging about large exhausts......
3" is excessive. 4" is full on retarded. Clogged cat? Replace it or run stock size straight pipe in place. Get an aftermarket muffler like a Flowmaster 80 series, and have the tips turn down. It'll be loud, sound good (at idle), and flow better than stock.
Old Jun 3, 2013 | 07:29 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Dude, no... Flowmasters sound like absolute junk on even a decent running V6. Why you would want to pay $80+ for that noise is beyond me (as it is with the whole fart can thing). There are mufflers out there that cost half as much that sound much better.
OP, there is a thread titled "the best mufflers for V6"... Might want to browse through it if you're determined to put on a full exhaust from the cat back. But you need to replace the cat with a direct fit first.
And, for the love of Pete, do NOT get an exhaust for your V6 with any pipe larger than 2.5". Unless you want to sound like junk.
Old Jun 3, 2013 | 07:33 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
2.5" is as big as you should go. No Flowmasters either, If you want that Chambered sound then go for a Hooker Aerochamber. It won't drone, has a decent idle and sounds great at WOT.
Old Jun 3, 2013 | 07:34 PM
project89's Avatar
if the guy is bending up the ex system himself with a bender use 2.75 inch pipe
the reson being most ex shop benders are crush or kink benders , and were the bends are the pipe size is greatly reduced cause the bender crushes the pipe
Old Jun 3, 2013 | 07:39 PM
Engine: 450HP 355
Transmission: TH350
True but a stock or mild 2.8/3.1 won't out-flow a 2.25" pipe let alone a 2.5".
Old Jun 3, 2013 | 07:41 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Don't get flowmaster, just like the others said. They sound like crap. I had a dual ex set up with them back when I got my car and it was horrible.
Dynomax sounds good IMO. Ive linked this before but its the only really good sound clip I have of the system. 2 1/2 inch to the muffler, then 2 1/4 out. Also had a magnaflow hi flow cat. Anything over 2 1/2 inch is overkill badly.
Old Jun 4, 2013 | 01:37 AM
caffeine's Avatar
Car: 89 Firebird Formula
Engine: 3500T
Axle/Gears: 9 bolt/4.11
3" only if you're planning on making a lot of power. 2.5" max I'd say for anything N/A. I like the sound of my OBX exhaust and it's pretty cheap. It is 3" though. Dynomaxes sound really good too.
Totally agree that 4" would be retarded, not to mention expensive. I could be wrong but I believe you would actually lose power through a 4" exhaust because of having zero velocity.
Another thing to consider is the manifolds/y-pipe on the engine. If the y-pipe is smaller than 2.5" there's no way you could make more power with anything larger than 2.5".
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
knight72
Aug 10, 2015 09:32 PM
