Where to get this bolt
Old Jun 23, 2013 | 08:01 PM
K1ng0011's Avatar
Car: 1985 Camaro
Engine: 2.8L v6
So my 85 2.8L had a cracked cylinder head on the passengers side. So I got a new one and put it on. Got it all back together and started to put 50/50 in and I started to hear it coming out of my engine. Turns out at the back of the cylinder head behind and below the ignition coil bracket there is a bolt missing from the cylinder head, and either my old cylinder head had the bolt and I did not get it back or the new head is for a newer year v6. The reason I say that is I found another 2.8 at a junk yard and it was an 87 I think and it had a sensor while mine does not have a sensor. All of my cylinder head bolts have been put in too. The car in the junk yard was towed off before I had a chance to get the tools to take it out. My guess is that its a water temp sensor. I just need a screw to put in that hole does anyone know what goes in it? Right now I have the biggest bolt I could find with some gorilla glue to hold it on and I want to actually fix it.
Last edited by K1ng0011; Jun 23, 2013 at 08:05 PM. Reason: Clafication of the issue
Old Jun 23, 2013 | 08:22 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Where to get this bolt
3/8 NPT pipe plug... Go to your hardware store.
Old Jun 23, 2013 | 10:49 PM
K1ng0011's Avatar
Car: 1985 Camaro
Engine: 2.8L v6
Great thanks for the help. I am curious though how do you know its that size? Have you had this issue or do u have a manual that tells you? My chilton is not that detailed.
Old Jun 24, 2013 | 10:27 AM
Engine: 2.7L V6
Axle/Gears: 4.41
I had to move the CTS in my 3100 intake... The sensor was in the way of my heater hose. The fan switch and the CTS and temp gauge/light sender are all the same thread type. The info is also found scattered around the Web.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
