boging down
Old Jun 23, 2013 | 08:00 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
boging down
ok, i have had a few other threads and now im having a dif problem so im starting new...
the engine bogs down if you give it more than about 1/4 throttle.. once in a while , if i let it idle for a bit i can get it to climb fairly high in the rpm range without it bogging down, as long as you move slowly... and quick movements on the throttle will bog it out....hit the throttle hard? it cant keep up.. ...note .. the car is not derivable do to the excessive loss in power...but does idle nicely lol
Old Jun 23, 2013 | 08:01 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Re: boging down
some one give me direction lol,,, im now at a loss
Old Jun 23, 2013 | 08:50 PM
Stewie's Avatar
Car: 1992 Firebird
Engine: 3.1L
Transmission: Manual T5
Axle/Gears: Stock
Re: boging down
What have you checked so far? Have you checked your fuel pressure? A clogged fuel filter or bad fuel pump can supply enough fuel to idle, but not much more. A bad FPR or injector(s) may do something similar. I've had bogging down problems which were partially related to a bad IAC. A bad ICM can also do strange things.
What repairs have you done in the past? For instance, if we know you installed a fuel filter recently, then we can eliminate that as the problem.
Try narrowing it down to fuel or electrical.
There is also a GM Bulletin on bogging down problems for '90-'92 3.1L engines. Is your car acting like this: https://www.thirdgen.org/forums/v6/8...-you-have.html
Old Jun 23, 2013 | 09:15 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Re: boging down
ok, so my tps reads .68 idle and 4.68 wot
my map reads 1.89 idle
fpr is new,
filter is new
fuel pump is about a year old. its a venom pump.
pressure while running read 45psi...
coil is new spark plugs are new
injectors are about 5 months old
knock sensor and harness wire are new
timing has been reset to 10*
headers and full exhaust including oxygen sensor are a month old
and i added a air fuel mix gauge
Old Jun 23, 2013 | 09:45 PM
Stewie's Avatar
Car: 1992 Firebird
Engine: 3.1L
Axle/Gears: Stock
Re: boging down
Great info. You might try pulling off the IAC valve and clean it up with Throttle cleaner. It should be 1 and 1/8 inch from the end of the pindle to the neck. Be careful removing the bolts, they break easy. You may want to use a light hammer to tap on the bolts to break them loose. Also, clean up the carbon inside the IAC connetion. See if that helps.
Are you getting good spark to the plugs. Have you pulled a couple out to see what they look like. Again, an ICM going bad can do screwy things. I'm sure some others with more expertise than me will add to your thread some other things to check out. Good luck. Hope you get it running soon.
Old Jun 23, 2013 | 09:52 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Re: boging down
plugs are new. coil is new. ill check the plugs again..icm is new also
Old Jun 24, 2013 | 01:01 AM
morrow's Avatar
Car: 92 Camaro Rs.R
Re: boging down
so i pulled the plugs again. first off , i put them side by side with the ngk plugs i have..the ngk plugs sit deeper into the cylinder.. the electrode at the end of the plug is longer, so im going back to the ngk plugs... and second... somthing doesnt look right, to say the least lol
the first picture is all the plugs next to eachother, the three on the right are from the passenger side, and the three on the left are the drivers side
http://i66.photobucket.com/albums/h2...ps7d0051a1.jpg
these plugs have been in for two days and only run at idle... highest rpm seen is 2200
looks to me that the passenger side plugs aren't getting much fuel?
Old Jun 24, 2013 | 10:46 AM
morrow's Avatar
Car: 92 Camaro Rs.R
Re: boging down
bump
Old Jun 24, 2013 | 03:05 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: boging down
What kind of plugs are those? They almost look like platinum ones. Id use nothing but Ac Delco R43ts or R44ts for your application. There less exspencive and are what is suppose to be in there IIRC. I've always ran Ac Delcos in my Camaro.
Old Jun 24, 2013 | 09:49 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Re: boging down
Ok I took them to autozine and they gave me a new set.ac Delco43
thatoneguy5x
Jan 25, 2013 03:28 PM
cs11091
Dec 5, 2008 06:18 AM
1987_Z28
Carburetors
May 1, 2007 12:54 PM
steve's Z28
Aftermarket Product Review
Dec 8, 2005 03:18 AM
Streetterror
Mar 27, 2005 04:21 AM
