Low power and check engine light
Old Jun 28, 2013 | 09:22 AM
K1ng0011's Avatar
Car: 1985 Camaro
Engine: 2.8L v6
I have a 1985 v6 2.8L Camaro. I replaced a cracked cylinder head and had the other machined. So when I got it back together I have two problems. The first being a check engine light with the code 22. I had this issue before when I first got the car. I replaced the tps sensor like 4000 miles ago to try and fix the issue. It turned out to be just a vacuum leak. Now I have this code again. I cannot find any vacuum leaks. When I am accelerating the CEL goes away but when I slow down it returns. The second issue is no power at around 50mph. Even with the pedal floored I bairly gain any speed. The idle is also faster than it should be. The Throttle response feels pretty good. I think the second issue is caused by the timing being off what do you guys think?
Old Jun 30, 2013 | 08:07 AM
ex-x-fire's Avatar
Re: Low power and check engine light
Recheck the timing, follow the instructions on the emissions label.
Old Jun 30, 2013 | 11:33 PM
K1ng0011's Avatar
Car: 1985 Camaro
Engine: 2.8L v6
Ok don't have a timing gun on hand but I will try and get a hold of one and see if that's the issue which I think it is. I have been doing it by ear so far and I can get it to slow down the idle by retarding the timing but then the car will not run right. So I advance it a hair at a time but it just idles fast when I get the idle to smooth out. I would say its idling around 1000 rpm or so (no rpm gauge in the dash).
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
