Am i right? Error codes
Old Aug 13, 2013 | 06:02 PM
firechicken8292's Avatar
are theses codes 12 and 13?
Old Aug 14, 2013 | 12:24 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Am i right? Error codes
It's hard to tell. The video was very jerky for me at least. Was it 13 and 14? The 12s are just a signal that the ecm is communicating correctly. It's the codes between the 12s that count. 13 would be O2 sensor and 14 Coolant temp. May want to check them.
Old Aug 14, 2013 | 06:10 PM
Mark RWC's Avatar
The code 12 showing it is in diagonistic mode is first. The second looks like 13 so you are correct in your 12 and 13 showing.The 13 is your only error code from what I saw.
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
3rdgenparts
Sep 28, 2015 10:47 PM
mfp189
Sep 27, 2015 09:25 AM
