Will these cylinder heads work on the 1986 2.8L v6?
Old Sep 11, 2013 | 12:36 PM
CamaroPaul's Avatar
Car: 1986 Camaro Sport Coupe
Engine: 2.8L V6 Multi-Port Fuel Injection
Transmission: 700R4 / 4 Speed Automatic
GM 2.8L V6 Aluminum Cylinder Head #52363014
Old Sep 11, 2013 | 12:37 PM
CamaroPaul's Avatar
Re: Will these cylinder heads work on the 1986 2.8L v6?
http://item.mobileweb.ebay.com/viewi...d=360203967241
Old Sep 11, 2013 | 03:26 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
No those wont work right on your thirdgen f-body iron headed 2.8L as a bolt on item. I never knew there was aluminum heads on a S-10 2.8L. I thought only FWD cars had the aluminum heads. The pictures on the link remind me of gen 3 heads. Im sure the compression would be insanely high if you put them on your car. The chamber is about half the size of the iron heads. Id bet 13:1 or greater compression ratio if you just bolted those heads on and made it work without swapping out the current pistons you have.
Old Sep 11, 2013 | 03:32 PM
CamaroPaul's Avatar
Thanks for responding I appreciate the help.
Old Sep 11, 2013 | 03:35 PM
fasteddi's Avatar
Car: 1991 Camaro RS
No problem. FYI your stuck with iron heads on that car unless you do a hybrid aluminum head swap. For more info just google "hybrid V6 thirdgen" and you'll find tons of info on it.
Old Sep 11, 2013 | 04:26 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Hey Paul you beat me too it lol, I was going to research here for you.
NinjaNife
Aug 23, 2015 11:49 AM
db057
Aug 22, 2015 08:17 PM
redmaroz
Aug 16, 2015 11:40 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
