smog delete bracket broke
Old Dec 9, 2013 | 06:28 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
any one have a part number for the gm v6 smog delete pulley and bracket assembly?
just broke.. nice way to end the day after work. start the car and bracket brakes... grr. like 10 degrees out also...
Old Dec 9, 2013 | 06:49 PM
1991sleeper's Avatar
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
I removed my smog pump and just used a longer belt and a different belt routing no delete pulley here
Old Dec 10, 2013 | 05:33 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: smog delete bracket broke
He's right, you can just take the pump off and get a belt for a car w/o AIR. If you don't have A/C, I believe you need a 82.5" belt, not sure on the size for w/ A/C though.
Old Dec 10, 2013 | 12:15 PM
enswrob's Avatar
Car: 89 Firebird
Axle/Gears: ?
got a shorter belt for now.. now to find a bracket and pulley.
Old Dec 10, 2013 | 01:34 PM
drdave88's Avatar
Engine: 6.0L
You don't need the bracket and pulley, you can run it just with the shorter belt and be fine. I ran mine like that for a decade.
Old Dec 10, 2013 | 08:56 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
915K6 for A/C with no AIR, 815K6 for no A/C no air...
Factory non-AIR cars do NOT have any AIR parts period... My 87 auto never had any AIR parts until the 3.1 was put in and then it got the bracket (which was removed) and the pass side exhaust manifold check valve (which was forever coming loose from the manifold and leaking ).
Long story short... If you've already gotten rid of the pump, get rid of the brackets and headaches as well. And you will end up with one less moving part to potentially fail (the pulley).
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Silver Spear
South East Region
Sep 8, 2015 12:06 PM
Silver Spear
South East Region
Sep 8, 2015 11:59 AM
mantaguy
Sep 2, 2015 10:42 PM
