did auto to manual swap.. now car runs like crap.
Car: 1992 firebird
Engine: 3.1.... soon to be... bigger.
Transmission: 700r4, looking for t5
Axle/Gears: I havent a clue.
since the swap was done the computer tries to step up the idle when i let out the clutch, so to make it behave and atleast driveable, ive unplugged the IAC. i guess it thinks the engine is dying. do i need to change the computer and the prom? or just prom? or is it a different issue alltogether?
Transmission: 5-speed/T-5
Re: did auto to manual swap.. now car runs like crap.
Did you change anything to do with the ECM when you did the swap?
Car: 1992 firebird
no, all electronics are stock auto.
Then yes, you need to swap the PROM to a manual PROM. Depending on the actual ECM you have an ECM may be required, but not usually.
Car: 1992 firebird
its a '92 ecm... but i still have no idea... i can get a manual prom from autozone for about 60 bucks, but they need the code from the prom, (the manual trans prom code) where can i find this info?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
the bccs are listed here
http://www.3rdgenformula.com/92/promcodes.htm
Car: 1992 firebird
but i dont have a big block....?
Car: 1992 firebird
oh! sorry i red that wrong, my fault.
Car: 1992 firebird
so according to that chart in the link, i shouldnt need a new ECM right? just a new prom chip
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Email Tuned performance, have him make you a prom. Don't buy one from Autozone.
Car: 1992 firebird
will it be cheaper than $60 bucks? im kindof on a budget....
Car: 1971 Camaro
Engine: 427
^ His prices are listed in the post, or you could ask him. All his contact info is there as well.
Car: 1992 firebird
i pm'ed him, he seems to specialize in v8 stuff.. maybe he has a spare memcal laying around....
Engine: Lb9
Transmission: M20
Sending a reply to your pm
Being a 1992, the ECM should be a '7730, and you will only need a new MEMCAL. The MEMCAL contains the PROM.
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Speaking from experience:
YOU DO NOT NEED TO DO ANYTHING WITH THE ECM. Period. End of story.
Except for maybe a few months out of 4 years (took forever to find the HNL PROM), I ran my manual trans swap on an auto PROM. Never had any issues with running except when certain sensors and even a couple ECMs died.
Yes, the idle speed will hold where it is and even run a bit higher because the engine has been unloaded for the moment. But that is no reason to go and unplug the IAC. It's fine. Plug the IAC back in and leave it alone. If it's running well, you have nothing to worry about. If it's running like crap, start checking things over and leave the ECM until last if all else fails.
Car: 1992 firebird
thats the thing, being that its an auto memcal, the engine thinks theres a load when i release the clutch so the idle jumps up to about 2000 rpms. and doesent come back down. so to avoid this, ive set and unplugged the iac so the engine will idle steadily.. somewhat... i think that unplugging the iac, it put the computer in limp home mode... the engine ran fine when the auto was installed, diddnt mess with anything else, i keep my car in tip top shape at all times, i even have a sort of pre-flight check lol.. engine oil, coolant, trans fluid, etc..
Car: 1992 firebird
there is no idle relearn on the 92's all you do is set the throttle stop and the computer does the rest. the IAC resets every keystroke.
u do not set the throttle stop
90-92 cars are the cars that u have to do an idle relearn on , the 85-89 2.8 cars not so much
Engine: Lb9
Transmission: M20
The only things I can think or is idle relearn or the orange/blk p/n wire is grounded. Or its with the calibrator .For a '90 through '92 with a manual tranny, it is rather easy. Or, at least easier then doing it on a auto tranny car.
For a full idle learn, disconnect the battery for about 10 seconds (or more). Then re-connect.
Start the car and just let it idle. The important items are to not touch the steering wheel (no pressure), and to have all accessories off (A/C, back light heater, and so on).
Wait until the engine cooling fan turns on, then off again.
Done, shut off the engine for at least 10 seconds. Then drive it.
As others have mentioned the idle learn on a stick car isn't that important. But if the ECM keeps losing battery power, it can be a pain.
OTOH, if it isn't battery being lost, there may be an issue with a sensor such as the TPS. Or an actuator such as the IAC.
RBob.
RBob.
Is your speedo correct? Are you using an SGI-5 adapter? With my T5-T56 swap there's something flaky in the adapter or the wiring, and if it's not working the car wants to die. As soon as the SGI is working it smooths right out.
Engine: Lb9
Transmission: M20
A intermittent loss of vss 24 would do that.
Car: 1992 firebird
the car idled fine before i removed the auto trans, i could start it, it would run through its warmup cycle, then idle down according to engine temp. it did this when i first started it after the swap too, i let it warm up before i went for a test drive. it ran fine just like normal, when i went for a drive for the first time, i put it in gear, and went to let out the clutch. well, i guess the engine sensed it as a load, and adjusted idle accordingly- up to about 2000 rpms when i disengaged the clutch. ive never had to do an idle learn. i work at a shop with access to shop key, mitchells, and alldata- none point to an idle learn that i know of. is there something more i need to do with the park/neutral switch? also, bear in mind that im still runnimg the auto memcal.. personally, i think this may be the source of my problem.. how does the manual memcal regulate the idle valve??
Engine: Lb9
Transmission: M20
yes the idle speed is referenced off cts. The p/n is a adder but only 50 rpm.
The p/n switch is in cavity D16 snip it or unpin it.
Yes, swap to a manual MEMCAL, and your problem should be resolved, provided there are no mechanical issues (pinched, cut wires, pinched hoses, etc), that happened during the swap. Things happen sometimes that we miss during a swap. It's happened to me, and will likely happen to me again.
About the idle re-learn thing. I've found ONE Car in all of my years of swaps and disconnecting batteries to perform electrical work that seemed to need an "idle re-learn" performed. If I were to do the math, that would be less than 1% of cars that were deemed to need an idle re-learn actually needed it.
Car: 92 Camaro rs ( mostly stock for now
Engine: 3.1 v6
Transmission: 700r4 with a b&m megashifter.
Axle/Gears: whatever came stock. wanna posi tho
Tuned performance did my 3.1 prom.
He does awesome work and knows everything about ecms.
Forget autozone. They will get it screwed up 95% of the time.
Just pm hotmail your engine, transit and rear gear ratio. Also if you want smog crap deleted he can program that as well.
his prices are very good. Judy hit him up. He'll get it running better than ever.
Car: 1992 firebird
update! i think i fixed it maybe... just went for a short cruise earlier, but before i did, i plugged in the IAC, started the car, let it warm.... and then switched the p/n switch to drive (or some other forward gear..) and the idle stayed rock steady even under a load. im thinking i could use this as a theft deturrent... lol run wires to a toggle switch under dash, flip switch one way to start, the other way for drive? but anyways, i drove the car to go get pizza, and it ran flawlessly. one more question though....
i swapped 4th gen pedals into the car. long story short, in order to get the right geometry on the master, i had to drill a hole in the pedal and put another peg in just low and in front of the original one, in order to get more throw at the master cylinder....
have any of you experienced this problem?
Engine: Lb9
Transmission: M20
Is it getting a code 24 ? I would think poor connection in that circuit or a issue with the sgi-5. The sgi-5 I have read can be kinda glitchy but as far as I know there is no other manufacture alternative. it depends how your using it idk if a drac could be used as a calibrated despite the low ppm input.
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Car: 1992 firebird
Sams n.y. pizza. Great stuff
Car: 1992 firebird
update! the car runs loads better, every time i go to leave, i switch the p/n switch to drive, and the ecm seems to suppress all the irratic idle issues..... except- when it goes into closed loop. like after a drive, and i stop at a stop light. its like when the idle drops for closed loop the iac goes nuts, ive driven it on the interstate at 80 mph, the car runs excellent- overdrive is the bees knees.. but... that surging idle...
Why don't you just get the proper MEMCAL?
This sounds like the logical solution . GM had a manual and an automatic tune as separate entities for a reason . If the same tune would have worked for both transmissions , don't ya think GM would have saved the money and went with a "one size fits all" tune ? Thread Starter
Car: 1992 firebird
thats what i figured too, just diddnt want to spend 60 bucks if i diddnt have too. is there anything i have to modify in order to get the manual memcal to work correctly?
Car: 1992 firebird
sweet.. thanks guys.
9192camaro
16
Feb 3, 2019 12:21 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
