hey guys therostat gauge ?
Old Jan 20, 2014 | 08:23 PM
vaspen's Avatar
Car: 00 benz and 83 iron bird
Engine: kompressor and 350 to 388
Transmission: outlaw 4 spdtns
well the gauge for temp isn't working on my friends 91 v6
I fixed his thermostat (also had a stipped bolt I had to rethread )
but his gauge isn't working
car has 177k on it hasn't ran sense 08 we went to start it finnaly but it wouldn't crank (starter pin/ vats issue ) we turned the block backwards a 1/4 inch smacked the starter and did a key reset
still wouldn't start ...
it was the ignition coil (figured that one by pulling #1 cyl plug slightly away from plug and getting no spark )
FINALLY !! it ran so we flushed fluids plugs super thick wires :3
slapped a no cat exhaust on
brought all the horses left back to life (she has a good bit of kick left in her lol)
so that's the story he has a bodykit he spent 1600 on(waiting on warm for bondo and paint)
new headlights from ebay (I recommend them makes quite a difference )
so how can I get this temp gauge working agen (I figure its the thermostat sensor by the thermostat under the throttle ?
also new member hi all :3 im personally planning on buying my other friends 83 f1 bird with a 388 ? current w.i.p. is a 00 c230 kompressor benz
Old Jan 21, 2014 | 08:21 AM
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Re: hey guys therostat gauge ?
2.8l, 3.1l? The sensor under the throttle body is the coolant temp sensor for the ecm, not the gauge. The gauge sender is in the front of the drivers side head IIRC. It has a single wire with white or black connector.
Old Jan 21, 2014 | 10:05 AM
vaspen's Avatar
3.1 sry and do u think you could grab a pic if u can ? we finally got it on the road yesterday so I wont be able to look at it till he comes back
Old Jan 21, 2014 | 12:11 PM
willexoIX's Avatar
I don't have a pic, but it should be behind the ac compressor with a single green/white stripe wire coming from it. I put a mechanical sender and gauge in mine.
BRoss99
Aug 10, 2025 05:08 PM
Infested
May 22, 2018 11:56 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
matthew911
Aug 12, 2015 09:38 AM
