Question about throttle postion sensor
Old Jan 28, 2014 | 06:04 PM
leo27030's Avatar
Car: 91 Camaro RS
Engine: 3.1 L V6
Transmission: Automatic
I replaced the throttle position sensor and after putting the new one in,when I started the car it would run like the pedal was to the floor and set off the engine light instantly . when I ran the codes it gave me 3 codes they were 22 , 32 and 35 I've already replaced the Map sensor and the idle air control also the EGR and many other parts before the above problem but when I put the old one back in it runs normal until it warms up good then when I stop at a light or any stop the rpm jumps a few times then it stalls but will start right back up
Old Jan 28, 2014 | 06:13 PM
project89's Avatar
Re: Question about throttle postion sensor
did u do an idle relearn , this is the main cause of stalling at lights or stops with a 3.1
Old Feb 23, 2014 | 09:34 AM
leo27030's Avatar
Car: 91 Camaro RS
Engine: 3.1 L V6
I tested the plug to the TPS and got the 5 volts I'm supposed to get , Then back probed the sensor while turning the butterfly shaft and it say's it should go from 0 - 5 volts when you turn it but mine only went to 4.3 volts
Old Feb 23, 2014 | 09:40 AM
jokerZ71's Avatar
Car: 97 Z71 Extended Cab
Engine: 5.7 Vortec
Axle/Gears: 3:42
More importantly than max voltage,did the values smoothly steadily increase w/o flat spots or fluctuating up & down.Also,are you getting full travel on the linkage?
9192camaro
16
Feb 3, 2019 12:21 AM
mdtoren
Aug 23, 2015 12:52 PM
redmaroz
Aug 16, 2015 11:40 PM
mdtoren
Aug 16, 2015 05:45 PM
squiggy2
Aug 9, 2015 09:30 PM
