3.1 throttle boddy bolts wont tighten down/
Old Mar 21, 2014 | 07:06 PM
mikey8494's Avatar
Car: 1986 camaro iroc z
Axle/Gears: stock
so as the title says thats whats hapening its causing me to have am major leak making my motor run bad so when i slide the bolts into the holes it will slide a ways with the threads untill it grabs half way down the bolt instead of threading from the begining of the bolt i bought brand new bolts and its the same thing i have no idea what to do and i cant just go by a nother intake plenum
Old Mar 21, 2014 | 07:16 PM
34blazer's Avatar
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
Re: 3.1 throttle boddy bolts wont tighten down/
Can you afford a heli-coil kit?
Old Mar 21, 2014 | 09:00 PM
mikey8494's Avatar
Axle/Gears: stock
from what im seeing in prices right now now i canis there a posibility to run a long bolt through each hole and putting a nut on each end and tighenting it down
Old Mar 22, 2014 | 10:41 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
I've had this happen on the fuel rail threads before on the middle intake. What I did was use a larger tap and just re drill and re tap the hole for a standard bolt. Although a heli coil is easier, I was in a pinch and that worked fine.
I'm sure they your threads are shot though by what your saying. Steel bolts really eat up the threads if there over tq'ed or cross threaded at all, since the intakes and such are aluminum.
Old Mar 22, 2014 | 02:16 PM
mikey8494's Avatar
Axle/Gears: stock
yea i cross threaded it does anyone know what helio coil kit i need is im trying to find it at autozone so i can get this beast on the road agian
Old Mar 23, 2014 | 11:00 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
I believe they're M8x1.25 but you should take one of the bolts to a hardware store where they have a thread gauge to be sure before you go and spend good money on a rethread kit that isn't going to work.
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
