Carbed V6, swapped plugs now idles crazy high... what'd I do?
Old Apr 9, 2014 | 05:38 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Did half the spark plugs on the 83 Firebird 2.8, fired it up to check something, and now even once warm and kicked down it idles at 2200rpm.
What wire or hose might I have bumped?
Hard to listen for vacuum leaks as the clutch fan is so loud but I don't hear anything obvious.
PCV is seated.
And yes, I did the other 3 plugs
Old May 6, 2014 | 09:14 PM
bison999's Avatar
Car: 1984 Firebird S/E
Engine: 2.8 carbed
Transmission: Warner T5 5 Speed
Re: Carbed V6, swapped plugs now idles crazy high... what'd I do?
I don't know if you ever figured it out, but a good way to check for vacuum leaks is to get some carb cleaner or starter fluid and spray near hoses or spark plug bases. Just be careful where you spray that stuff, you'll hear the idle go down when you hit the leak.
Old May 7, 2014 | 06:17 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I appreciate it man! Actually it turned out to be a wire that came off a spade connector near the back of the air cleaner area. Soon as I reconnected it the idle dropped!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
RedLeader289
May 28, 2019 01:47 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
lanceflame44
Sep 25, 2015 12:28 PM
Tylermcclinton
Sep 17, 2015 07:50 PM
