well this is a little problem
Old Apr 17, 2014 | 07:52 PM
JC1992rsconvert's Avatar
Car: 1992 camaro rs convertible
Engine: 3.1 liter v6
Transmission: automatic
Axle/Gears: 3.23 posi trac
so yea i finally after 2 days of working finally got my oil pan off and BAM right in the bottom of it was piston rings so now i have to figure out what to do you guys think i should do the block to the motor is not original but everything else is well this is a little problem-1922519_673989955995037_5787390245414707207_n.jpg
Old Apr 17, 2014 | 08:25 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: well this is a little problem
Your going to have to pull the motor anyway. Make a decision when you get it pulled.
Old Apr 17, 2014 | 10:48 PM
project89's Avatar
yup u have to tear everything down and inspect it all
Old Apr 22, 2014 | 08:37 AM
ok so ive been doing research on the hybrid swaps and my question to anybody is what would be the easiest and best swap i have a 3.4 complete engine out of a 1995 camaro with the ecm and wiring harness if i can use it great but when i say easy i mean like just bolt on nad bolt up i can have tuning done if need be i just really have to get my car running again not looking for power just maybe mpg
Old Apr 22, 2014 | 07:46 PM
camaroyoungster's Avatar
Car: 1985 Camaro Sport Coupe
Engine: Chevy 3.1
everything pretty much bolts right on if you use the existing ecm from your car now
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
