I got a code 45, how do I fix it?
Old May 22, 2014 | 10:10 PM
sheltonw3's Avatar
Car: 91' TRANS AM Modified
Engine: Classified
Transmission: Auto with Overdrive
I got the Oxygen sensor replaced, fixed the hole in the right valve pipe, and it went from a code 13 to a code 45, but in my manual it says "Rich Exhaust"...I pulled the TPS and cleaned it and the car starts up better and Idles rough at first start, but after 6 minutes, it gets better in Park, but it gets a really rough Idle in gear.
I even pulled the air filter, rotated it, and cleaned the tube and casing up and performed a Throttle body Cleaning, and it still has a rough Idle in gear, so how do I adjust the Fuel/Air Ration???
the car is a 91' 3.1 ltr, automatic
Old May 23, 2014 | 12:00 AM
Birdstheword's Avatar
Car: 1988 Pontiac trans am
Re: I got a code 45, how do I fix it?
I'd invest in a ADLD cable. only around 50.00 dollars and with it you can datalog and view live stream dat using WinALDL . it will save you a bunch of time and money. It's pretty easy to use. Think of what can upset the AFR .
Vacuum leak
exhaust leak before the o2 sensor
Bad CTS sensor
Bad o2 sensor
Bad TPS sensor
the rough idle could be from a dirty or bad idle air control valve.
Make sure you're getting good spark on all 6 cylinders . Also check EGR valve and make sure its not stuck open or there is a bunch of carbon build up int the egr port.
Old May 23, 2014 | 12:05 AM
sheltonw3's Avatar
Engine: Classified
the IAC was replaced, as well as the EGR, new spark plugs, new dist cables, oil change, fuel filter, the only things left to replace are the TPS, and or CTS*?...the O2 was replaced just two weeks ago, and the hole in the Right exhaust valve was sealed up*...so right now it is running Rich, so would I need a WinALDL cable to fix it with???
Old May 24, 2014 | 10:52 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Did you do an idle relearn yet? If not, disconnect the battery and do it.
Check your CTS resistance when cold and check the MAP and TPS output voltages at idle. And also check your injector resistances per bank (or injector, whichever is easier). Injector resistances should be no less than 11.8 ohms each or more than 4 ohms per bank.
You don't need an ALDL cable for 90% of diagnosis...
Old May 24, 2014 | 11:46 AM
No, it's just another tool that aids in fixing issues and saves you money and time. Like Maverick said, check your TPS and CTS. What WinALDL lets you do is view all sensor data in real time. you can also data log then afterwards go back and read your data . Here's a 'how to' video on TPS adjustment.
Code 45 and two zig zags, baby that's all we need ... bahahahahahahah
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
gta892000
Aug 11, 2019 11:16 AM
BumpaD82
Feb 26, 2016 02:57 PM
64Chief
Sep 12, 2015 08:05 AM
