3.1l 3100?
Old Jun 23, 2014 | 06:37 PM
1991rsguy's Avatar
Car: 1991 RS
Engine: 3.1L v6
3.1l 3100?
I found a freshly rebuilt 3.1l 3100 v6 would it fit In my 91 that has the 3.1 v6? It doesn't say if it is fwd or rwd.
Old Jun 24, 2014 | 04:58 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: 3.1l 3100?
Its definitly a 3100 FWD engine.
Old Jun 24, 2014 | 06:35 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Re: 3.1l 3100?
^ Agreed... the B on the block is a good giveaway too.
It will fit with a little work, and run very well too.
Old Jun 24, 2014 | 07:53 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: 3.1l 3100?
I'd say more than a "little work", especially for someone that has to ask if it's a FWD or RWD engine.
-new mounts
-modified oil pan or crossmember
-Prom swap or re-programming the ECM for the DIS ignition
-modified exhaust manifolds and Y- pipe or custom headers
-custom brackets for the belt driven accessories
-Modified bell housing to clear the new starter location
-sourcing of the missing parts assuming that all you get is what is in the picture
-a bunch of other small details
For some of us this is a "little work", for most however, this is a lot of work.
Old Jun 24, 2014 | 07:02 PM
Engine: 450HP 355
Transmission: TH350
Re: 3.1l 3100?
Pfft, that's a few nights in the garage with an 18 pack....
Old Jun 24, 2014 | 10:01 PM
1991rsguy's Avatar
Car: 1991 RS
Engine: 3.1L v6
Re: 3.1l 3100?
Yeah I'm young and new to this whole thing . But thank you! I'm just trying to get something new in my car . I didn't realize finding stuff for the v6 would be so hard. I just found out my cars odometer was rolled back before I bought it .😟 sounds like it would be easier/cheaper to have mine rebuilt .
Old Jun 25, 2014 | 05:14 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: 3.1l 3100?
There are plenty of parts for the v6, you just have to know where to look. check out the sticky at the top of the page, there are tons of aftermarket parts listed in there. Is there something currently wrong with your 3.1 as far as leaks or running bad? Or are you just wanting to freshen it up? Keep in mind, you aren't going to just drop a new/rebuilt engine in there and go out running with all the V8s unless you have a good amount of work. That said, it can be done. A lot of us have done it before.
Old Jun 25, 2014 | 12:06 PM
1991rsguy's Avatar
Car: 1991 RS
Engine: 3.1L v6
Re: 3.1l 3100?
Just trying to freshen it up .
jhawkeye
May 25, 2022 06:33 PM
HoosierinWA
Oct 7, 2015 10:15 AM
MitcherNeaf
Sep 24, 2015 09:23 PM
WIzmo
Aug 30, 2015 02:30 PM
dag19
Aug 26, 2015 10:22 AM
